2000 Dodge Ram 2500 Turbo Cummings Diesel
2000 Dodge Ram 2500 Cummins diesel
Well I bought a 2000 Dodge Ram 2500 Turbo Cummings Diesel Beautiful Truck ![emoji4] I am a 2nd Generation year 2000 ![emoji4]I have replace my Transmission with a brand-new one ![emoji52] Now its back in the shop because it was not geared right and it won't go up hills won't pull my enclosed trailer with my spider in it and it won't shift right between first second third and it makes the squally noise so we don't know what's going on with that but it's in the shop again![emoji35] I bought the truck to use it to pull whatever I wanted with it so I'm upset ![emoji34]Has anyone else had this problem?e78f3148086e8ba4b2271d6dd2400ab5.jpg
Gr8bawana
6.7 CTD
What do you men "it wasn't geared right"? That Cummins dieselsel should pull most anything you want. I doubt gearing is your problem.
beverlyquante54
It's in the shop where they put the new transmission in it they said they had to change the gearing in it or something line it up or something ![emoji52]
MADDOG
Not RamForum Staff
There's just not enough info here to be able to diagnose the problem completely.
if they put in a new or rebuilt transmission, and you are having a problem, it may be the wrong transmission, a bad torque converter, the torque converter failed to seat properly or there is an internal defect in the transmission itself.
Good luck!
beverlyquante54
They got it right this time it's running and shifting great ![emoji4]
beverlyquante54
Good luck!
Thank you MADDOG
It's a knew improved transmission for the track and it's working great now ![emoji4] Beside the oil leak witch we found where it's coming from and my fuse keeps pulling that work my mirrors and my domelight inside the truck ![emoji4] I might get it worked out cause I love my truck !❤️
jlbayes
2001 & 1997
5.9l cummins
Would put money on it they had the wrong year of electronics in the transmission.
beverlyquante54
My truck needs some loving care !❤️
beverlyquante54
Now Wayne said I need to put a new radio in my truck ![emoji4] What's out there for a 2000 Dodge Ram 2500 ?
MADDOG
Not RamForum Staff
I had a 1999 and found a nice Alpine head unit that fit great with no cutting or hassles.
You might want to check out their website.
beverlyquante54
Thank you [emoji4] I picked a Boss stereo out ![emoji847] I am so excited ![emoji4]
beverlyquante54
Now I have a new problem? Jumped in my truck and it well not start ![emoji45] I check the battery and the lights and the dumb like the radio the buzzer on the door everything works ![emoji35] It won’t turn over ![emoji857] I think it’s the starter or the wire or the ignition switch is bad not pretty at all ! [emoji36] I still love my truck but this really sucks [emoji19]
goodtodoo
1996 indy pace truck
Check the battery connections first.
VLG6963
