How do I tell if I have a mds problem?
Ryangio
If I am having a mds problem will there be a engine light that comes on or is that only sometimes. I notice when i am coasting between 20-30 mph that I hear a clicking like sound
corneileous
Podunkyville, OK
2018 Ram 1500 Limited 4X4
Take your truck to the local parts store and have them put their code reader on it to pull the code. Or if you don't wanna do that, you can do the "key dance" to pull the code that way which consists of turning the key on to run (don't start) then back to off, three times ending with the key on and the code, if there is one will be displayed in your odometer readout.
R
Ryangio
Their is currently no engine light on... the only symptom it have is when shlowing down is the ticking.
corneileous
Podunkyville, OK
You never know tho, you might have a stored code even without a light. If you check it right now and there is no code found or no light, wait until the light comes back on and then pull over and do that key dance I told ya about.
I'm pretty sure the computer at the Mopar house will give you a code history even if there is no light at the time but I'm not sure about the other, smaller and less-complex code readers.
corneileous
Podunkyville, OK
But definitely need to find that code from when the CEL comes on.
