Trupiano
Registered User
- Jun 27, 2010
- 10,981
- 725
- 2010 Ram 2500 6.7L CTD Crew Cab
- 6.7L CTD
2010-2012 6.7L Turbo Diesel Engine Service Info:
Engine Oil Filters: MOPAR# 05083285AA or MO-285 | CUMMINS# 3949561 | FLEETGUARD# LF3972 (standard 30 microns at 95%) or FLEETGUARD# LF16035 (upgraded/fluted stratapore version 30 microns at 100% / 10 microns at 60%) | AMSOIL# EA080 (15 micron at 98.7%) $18.85 each wholesale or $24.80 retail | ROYAL PURPLE# 40-780 (99% filtration at 25 microns) | DONALDSON# ELF7349 | WIX# 57620 (standard/20 micron) or 57620XE (high efficiency/14 micron) | NAPA GOLD# 7620XE (14 micron) | FRAM# PH3976A (standard) or HPH3976A (extended life) | BALDWIN# BT7349
Fuel Filters:
MOPAR 68157291 NANONET two stage fuel Filter (5 micron outer/3 micron inner) | MOPAR# 68065608AA (5 microns at 98.7%) | FLEETGUARD# FS43255 (5 microns at 98.7%) | CUMMINS# 4947561 (5 microns at 98.7%) | WIX# 33255 (12 micron at 100% / 5 micron at 98.7%) | NAPA# 3255 (12 micron at 100%) | Baldwin#
Air Filter: MOPAR# 53034051AB | FLEETGUARD# AF27684 | WIX# 46930 | NAPA# 6930 | FRAM# CA10261 | PUROLATOR# A56314 | DONALDSON# P616743 | BALDWIN# PA4318
68RFE Transmission (4x4 only): MOPAR Sump Filter# 5013470 | MOPAR Screw On# 5179267
68RFE Transmission (4x2 only): MOPAR Sump Filter# 5013470A | MOPAR Screw On# MOP-5179267
AISIN Transmission (4x2 & 4x4): MOPAR Sump Filter# 68019688 | MOPAR Pan Gasket# 68020049
Crankcase Vent Filter (CCV): CUMMINS# CV520010
Engine Oil Viscosity: In ambient temperatures below 0°F (-18°C) 5W-40 synthetic engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. In ambient temperatures above 0°F (-18°C) 15W-40 engine oil that meets Chrysler Materials Standard MS-10902 and the API CJ-4 engine oil category is required. *Change engine oil when prompted by the Engine Oil Indicator System or every 7,500 miles/12,000km or 6 months. Uses 12.1 Quarts/11.4 Liters/3 gallons. *Can use MOPAR DIESEL FRESH Oil Additive PN: 05139947AA to neutralize the smell during oil changes if preferred. The four-ounce Diesel Fresh bottle treats up to 12 quarts of diesel engine oil. For easy removal use this End Cap Filter Wrench: LISLE 54780 END CAP FILTER WRENCH-Dodge Cummins Diesel Truck Accessories – Geno’s Garage **Your vehicle is equipped with an engine oil change indicator system. This system will alert you when it is time to change your engine oil by displaying the words “Oil Change Due” on your Electronic Vehicle Information Center (EVIC). The engine oil change indicator system is duty cycle based, which means the engine oil change interval may fluctuate depending on your per- sonal driving style. Driving styles such as frequent stop and go type driving or extended idle time can increase the frequency of the engine oil change. Unless reset, this message will continue to display each time you turn the ignition switch to the ON/RUN position. To turn off the message temporarily, press and release the Trip Odometer button on the instrument cluster. To reset the oil change indicator system: (after performing the scheduled maintenance) 1. Turn the ignition switch to the ON/RUN position (do not start the engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary, repeat this procedure.
Transmission Service: Automatic Transmission (68RFE): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change automatic transmission fluid and filter(s) every 60,000 miles.
Automatic Transmission Chassis Cab (AS68RC): MOPAR AS68RC Automatic Transmission Fluid or equivalent. *Change every 30,000 miles (48,000 km) or 24 Months
Manual Transmission (G-56): MOPAR ATF+4 Automatic Transmission Fluid or equivalent. *Change the manual transmission fluid at 120,000 Miles (192,000 km) or 96 Months.
Fuel Filter Service: Replace fuel filter every 15,000 miles or 12 months using MOPAR Fuel Filter or equivalent. *Must meet 5 micron rating. Using a fuel filter that does not meet the manufacturers filtration and water separating requirements can severely impact fuel system life and reliability. For easy filter removal use this $6.95 Cummins Fuel Filter Removal Tool: LISLE 14600 CUMMINS FUEL FILTER REMOVAL TOOL-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Fuel Tank Capacity: 34 Gallons / 29 Liters (short bed) or 35 Gallons / 132 Liters (long bed). *Commercially available fuel additives are not necessary for the proper operation of your Cummins diesel engine. Use MOPAR Premium Diesel Fuel Treatment # 5191800 or equivalent as needed. Use Valvoline Synpower Diesel Injector Cleaner or equivalent as needed to clean and lubricate injectors and pump.
Radiator Service: Use MOPAR Antifreeze/Coolant 5 Year/100,000 mile formula or equivalent. *Flush and replace engine coolant every 60 months or replaced at 97,500 miles (157 000 km). Uses 5.7 Gallons or 21.4 Liters of coolant
Transfer Case Service: Change the transfer case fluid (4x4) every 60,000 miles (96,000 km) or every 48 months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent. Fluid level can be checked by removing the filler plug and inserting a finger. The level of the lubricant should not be more than 1/2 in (12 mm) below the bottom of the filler hole while the vehicle is on level ground.
Power Steering Service: (3500) Flush and replace power steering fluid at 97,500 Miles (157,000 km) or 78 Months. (2500) Flush and replace power steering fluid at 105,000 Miles (168,000 km) or 84 Months. Use MOPAR ATF+4 Automatic Transmission Fluid or equivalent.
Front/Rear Axle Service: Inspect the front (4x4) and rear axle (2x4 & 4x4) fluid and change if using your vehicle for police, taxi, fleet, off-road or frequent towing every 15,000 miles (24,000 km) or 12 Months. Rear Differential: (8.5 pints or 4.2 quarts (LSD) / 8.9 pints or 4.5 quarts (Open) Front Differential: (4.7 pints or 2.4 quarts)
Front Drive Shaft: Grease Front Driveshaft Fitting at each oil change interval, every 7,500 miles or 6 months. Use MS-6560 Lithium Base Grease #05083150AA or equivalent. (must use grease gun needle adaptor) Buy Performance Tools 4" Grease Gun Needle Nose Adapter W54216 at Advance Auto Parts Here is a picture of where the fitting is on the driveshaft:
Clutch Linkage: Lubricate using MOPAR® Multi-Purpose Grease, NLGI Grade 2 E.P. or equivalent.
Crankcase Ventilation Filter (CCV): Replace Crankcase Ventilation Filter every 67,500 miles (108,000 km) or every 54 Months. Use MOPAR CCV Filter or equivalent.
Diesel Particulate Filter (DPF): Clean every 200,000 miles, 6500 hours (anually if used vocationally) or if notified by by on-board computer.
Overhead Adjustment: Adjust every 150,000 miles, 5,000 hours or 4 years. (any excessive lash or need of constant adjustment may indicate tube, rocker, and or camshaft are damaged)
Cabin Air Filter: Add this mod to ensure proper HVAC air flow inside the cab and replace as flow decreases or filter gets dirty. DODGE RAM CABIN AIR FILTER KIT ('10-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
EGR Cleaning Kit: 6.7L EGR CLEANING KIT W/O FILTER ('07.5-'12)-Dodge Cummins Diesel Truck Accessories – Geno’s Garage
Turbo Drain Tube: The stock drain tube is only about 9-1/2" long and too short for aftermaket turbos unless you get lucky(extremely unlikely). The 3rd gen turbo drain tube is 11" long and fits way better. Cummins PN# 3970875 or get it here: Cummins Stock Length Flexible Turbo Drain Tube 5.9L 3970875 don't forget to get a new turbo drain gasket PN# 5264568
* Any brand product that meets or exceeds the factory OEM products “should” be ok to run however I would like to point out that Cummins developed Cummins Filtration in 1958 to meet the high performance requirements of Cummins diesel engines and manufactures Fleetguard filters. Cummins also endorses and recommends Valvoline Oil. This by no means discounts other brand products or quality but many will argue these Cummins endorsed/manufactured products are the best for a Cummins engine.
With that being said here are some products/feedback/prices and places to buy them from. Feel free to post your favorites or comments on products for the 6.7L
Fuel Filters:
