Step in and out of your truck's cab with confidence with our automatically retractable power running boards by AMP Research. Manufactured with durability and quality in mind they will provide you with safe and easy access to your truck's cab and bed. Being wisely designed they won't decrease your ground clearance and will hide under the rockers when not in use, reducing aerodynamic drag and making your truck look more clean.
Purchase any set of AMP Research PowerStep, PowerStep XL or PowerStep XTreme running boards and get up to $150 back!
This offer is valid till September 30, 2017.
Make sure to complete the following PDF to redeem your Visa Card.
Get faster, easier and safer access to your cab and bed with AMP Research automatic power Running Boards!
