2000 CTD 2500 won’t start.
Warwagon
5.9l HO Cummins Turbo Diesel
Okay have 2000 Ram 2500 CTD. Have replaced starter, starter relay. Checked all battery connection.
Turn key to on position all lights come on and go off. Wait for wait light to go out, turn key to to crank position but nothing from starter. Any help?
jlbayes
2001 & 1997
5.9l cummins
Will it crank if you jump the starter relay? Are you getting power on the signal wire when cranking?
W
Warwagon
Not sure how to jump the relay. Is the signal wire the thin one.
W
Warwagon
Fixed, another fuse under hood. Over looked. Thanks anyway.
