How to Install coil spring lowering kit (Ground Force)
quietpeen
2021 TRX
Hellcat
nice write up trup
ol'red02
Suffield, Ct
Damn! Usually not a fan of lowered trucks, but yours looks awesome man
blackout11
alpharetts GA
2011 R/T
A quick tip with the rear shock bolt if you have a spare wrench laying around cut it in half and it makes it easier to get the nut lol
shostopper17
Came out sickk man cant wait to do this to mine how much did the kit run you and where did you order it from?
RamFan2
I know this thread is a bit old but... I've been thinking about doing the Ground Force 2" rear drop. Do I still need to drill new holes for the sway bar?
RamFan2
That's what I thought but I wanted to make sure.
a_guerrajr
Houston
HEMI 5.7
Is the drilling necessary if you do the 2" coils instead of the 3".
The 2" kit doesn't seem to have any thing about end link spacers.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
I didnt on mine, 2" drop, simple 30-40 minute install.
a_guerrajr
Houston
HEMI 5.7
lol i just realized the post above mine was asking the same thing.
Exhausted
Edmond, OK
Do you have a picture of the spacer used on the swaybar end link?
I did my 2/4 drop and the new end links have polyurethane bushings and the are so noisy
So I thought I may reuse the stock end links and drill a higher hole like you did.
am3334
