P0456- code randomly appears
Zachohs
Archer City, TX
So the code (P0456 Evap Leak Monitor Small (0.020) Leak Detected) keeps on reappearing and I clear it. But, I'm getting tired of it appearing and suggestions on what is throwing the code and how to fix the problem?
Thanks,
Zach
Hammer_Z71
The infamous "gas cap code" that's almost never the gas cap. You can start there but it's probably a failed hose clamp or a split hose end in the evap system, usually around the canister. Chrysler uses about the cheapest hose clamps...
Z
Zachohs
Archer City, TX
ok, thanks, I'll check those after school. It's not the gas cap; I changed that out when the code first started appearing and the code kept coming back. So thanks for those suggestions.
Z
Zachohs
Archer City, TX
oh another thing, could it also have to do with my a/c not blowing cold when it is in park or stopped like at a stop sign? thanks
Z
Zachohs
Archer City, TX
well, it started raining yesterday and didn't feel like getting under the truck and looking while in the mud. So I decided to just hose my truck off to get some of the mud off from when it last rained and I had a little fun playing. I will look today and see what all it might be.
Z
Zachohs
Archer City, TX
after such a long time, I managed to get a part number of a hose that was cracked at the ends: 52121072AB, yet when I search the internet no part with this number comes up
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
A local parts store should be able to cut you off a matching hose in a bulk length unless it has a weird fitting it needs.
