Badge removal
dangrs158
What is the best way to remove the factory badges on my 2012? I want to clean up the look and remove the 4 X 4 from the tailgate and the Ram 1500 from the doors.
02hairlessram
I have always used fishing line to take them off and acetone to remove the glue and sticky junk. Never had a problem with it.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
quietpeen
2021 TRX
Hellcat
fishing line to remove. Have to do a sawing action. Then the easiest way to remove the residue is to use an eraser wheel.
shostopper17
What i used to do mine was a bottle of goo gone and i sprayed the logos all around, ram 1500 and 4x4 and than used high tense fishing wire to take off the badges from behind. Its only 3m tape holding them on. than i used some warm water and dish soap to wipe off all the goo gone and some of the 3m tape left behind. Now you may see ghost letters after you wash it forth first time but after the 3rd wash it will be gone
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
fishing line and GooGone, took me about 20 minutes to debadge.......
drinkamonster
4.7L V8
I just debadged my 02 and I have a few spots where there is an outline of the badge. It's not leftover 3m tape residue, it seems like it's in the clearcoat maybe? Is there anything I can do to buff this out?
I just got the truck a few days ago... I'm trying to clean it up real nice to take some pictures to post and introduce myself :)
Deviate
St. Augustine, FL
2005 4x2
After I debadged mine with fishing line and cleaned it goo gone, I used a little rubbing compound to get rid of the outline and then waxed it really good. Couldn't even tell there was anything there. Of course my truck is silver so it doesn't show fading as bad as a darker color would.
blackout11
alpharetts GA
2011 R/T
its a 2012 think his will come off with goo gone and some thumb rolling lol
Luke(MI)
Banned
1998 Chevy Blazer
4.3l Vortec V6
3M adhesive remover works wonders
Blackline
Hemi 5.7 L
I used the fishing line method, and then rolled up an edge and just pulled it back at a 45 and the adhesive came right off in one piece. I finished it up with a little goo gone, rubbing compond, and wax. It looks awesome!
MoparMulisha
New Windsor, MD
Using a heat gun (or blow dryer) gets the badges off faster with the help of some fishing line and then goo gone and like they said use wax or claybar to get rid of the ghost effect left.
D
dangrs158
Worked great
I can't believe how easy that was. Fishing line, a little rub with my finger, a little Goo Gone, and their gone. Thanks for the help.
macmongrel
Alaska
Ok Im convinced...Ill be debadging today before my first Fukken...For some reason I was hesitant to do this...I dunno call me sentimental...I feel like it'll make less factory- Then Igot to thinking isn't that the point...Plus Since My truck sits higher than stock 3500's It'll make people wonder what my truck is more once its debugged...Ill post photos after work
macmongrel
Alaska
Ok so HELP! Do I need to repair my door now! I live the way it looks with no RAM1500 but look at my door! What do I do? ImageUploadedByTapatalk1335849868.299988.jpgafter scrubbing and scrubbing to try and get the glue/ 3m tape off the door is all dull and you can still see the badging leftovers...
Grubrunner
Spot on!
Wax, not claybar, has always worked for me.
I'm still yet to pull any badges off of mine [though the rear 4X4 looks more-n-more out of place everyday so I'm close to removing it] but this is the EXACT method I've used on several previous rides with superior results.
The heat gun is a time-killer.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Ok so HELP! Do I need to repair my door now! I live the way it looks with no RAM1500 but look at my door! What do I do? View attachment 4980after scrubbing and scrubbing to try and get the glue/ 3m tape off the door is all dull and you can still see the badging leftovers...
fukk it!
shostopper17
Same problem happend to me just get some Googone and a terri cloth and some warms dish soap and water and you may have ghost lettering after but once a nice wax it will be gone
MidnightRambler
North Carolina
HEMI 5.7
Hey anyone with a 2011 or 2012 want to sell their tailgate badge? I noticed for the first time today that I actually like the bigger ram on the newer trucks, I have I 2010 so I'd like to rebadge mine and stick on a bigger one
