2nd Gen Recalls
Status
Not open for further replies.
L
lilfroger
5.9 CTD
Recall 00v007000: Lower control arm
Nhtsa campaign #: 00v007000
make: Dodge
model: Ram
year: 2000
mfr campaign #: 861
component description: Suspension:front:control arm:lower arm
manufacturer: Daimlerchrysler corporation
begin date of manufacturing: 19991003
end date of manufacturing: 19991105
potential # of units affected: 76
date owner notified by mfr: 20000320
manufacturers of recalled vehicles/products: Chrysler group llc
report received date: 20000111
record creation date: 20000114
regulation part #:
Federal motor vehicle safety standard #:
Defect summary:
Vehicle description: Light duty pickup trucks. The welds at the right side lower control arm bracket to axle tube attachment may have inadequate fatigue life due to poor weld quality. This can lead to separation of the control arm bracket from the axle tube.
Consequence summary:
If the bracket separates the vehicle could experience reduced directional stability, braking degradation and/or vehicle pull under braking.
Corrective summary:
Dealers will replace the front axle with a properly welded front axle.
Recall notes:
Daimlerchrysler recall no. 861.owner notification began march 20, 2000.owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-992-1997.also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 00v107000: Trailer hitches
Nhtsa campaign #: 00v107000
make: Dodge
model: Ram
year: 2000
mfr campaign #: 872
component description: Trailer hitches
begin date of manufacturing: 19980101
end date of manufacturing: 19990930
potential # of units affected: 357000
date owner notified by mfr: 20000424
report received date: 20000411
record creation date: 20000428
regulation part #:
Defect summary:
Vehicle description: Pickup trucks equipped with optional trailer hitch. The trailer hitch side brackets were manufactured using material with insufficient strength.
Brackets built without proper material could fatigue and fracture in the area where the trailer hitch mounts to the frame.
Corrective summary:
Dealers will inspect the trailer hitches and replace any trailer hitch showing signs of fatigue cracking. If no evidence of cracking exists, the dealer will install two reinforcement brackets.
Recall notes:
Owner notification began april 24, 2000.owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-992-1997. Also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 00v135000: Ignition switch
Nhtsa campaign #: 00v135000
make: Dodge
model: Ram
year: 1994, 1995, 1996
mfr campaign #: 875
component description: Electrical system:ignition:switch
begin date of manufacturing: 19930601
end date of manufacturing: 19960415
potential # of units affected: 690000
date owner notified by mfr: 20000626
report received date: 20000510
record creation date: 20000511
regulation part #:
Defect summary:
Vehicle description: Light duty pickup trucks. The affected vehicles were built with an ignition switch and wiring that could overheat. High electrical current loads pass through the switch when the blower motor is operated on high for an extended periods of time.
This could cause the ignition switch and wiring to overheat.
Corrective summary:
Dealers will install a relay and overlay harness.
Recall notes:
Owner notification began june 26, 2000. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-992-1997.also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 00v307000: Upper control arm
Nhtsa campaign #: 00v307000
make: Dodge
model: Ram
year: 2001
mfr campaign #: 955
component description: Suspension:front:control arm:upper arm
begin date of manufacturing: 20000715
end date of manufacturing: 20000719
potential # of units affected: 480
date owner notified by mfr: 20001030
report received date: 20001012
record creation date: 20001024
regulation part #:
Defect summary:
Vehicle description: Quad cab pickup trucks. The upper control arms attached with cadmium coated nuts can cause the bolts to stretch due to the application of a higher than specified clamp load. Breakage of the upper control arm fasteners could cause the axle to rotate forward under braking conditions.
This rotation could twist the steering linkage and possibly separate the brake lines, increasing the risk of a crash.
Corrective summary:
Dealers will replace the upper control arm bolts and nuts.
Recall notes:
Owner notification began october 30, 2000.owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-992-1997. Also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 00v366000: Child seat
Nhtsa campaign #: 00v366000
make: Dodge
model: Ram
year: 2001
mfr campaign #: 957
component description: Child seat
begin date of manufacturing: 19990615
end date of manufacturing: 20001031
potential # of units affected: 1211756
date owner notified by mfr: 20001112
report received date: 20001109
record creation date: 20001115
regulation part #: 571
federal motor vehicle safety standard #: 225
defect summary:
Vehicle description: Certain passenger vehicles, pickup trucks and sport utility vehicles fail to comply with the requirements of fmvss no. 225, "child restraint anchorage systems." some of the owner's manuals for these vehicles are missing instructions that provide a step-by-step procedure, including diagrams, for properly attaching a child restraint system's tether strap to the tether anchorage.
In the event of a crash, the child seat may not be properly attached increasing the risk of injury to the child.
Corrective summary:
Owners will be provided with an addendum to the owner's manuals.
Recall notes:
Owner notification began november 12, 2000.owners who do not receive the free owner's manual addendum within a reasonable time should contact daimlerchrysler at 1-800-853-1403.also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 01v008000: Rear suspension
Nhtsa campaign #: 01v008000
make: Dodge
model: Ram
year: 2001
mfr campaign #: 966
component description: Suspension:rear
begin date of manufacturing: 20000623
end date of manufacturing: 20000731
potential # of units affected: 2400
date owner notified by mfr: 20010205
report received date: 20010105
record creation date: 20010111
regulation part #:
Defect summary:
Vehicle description: Quad cab pickup trucks equipped with a camper package and overload springs. The rear axle spacer plate could lead to deformation of the upper spring plate during assembly of the axle to the vehicle resulting a soft joint.
The soft joint could cause the rear axle u-bolts to lose clamp load, resulting in displacement of the rear axle and a loss of vehicle control. This could increase the risk of a crash.
Corrective summary:
Dealers will remove the spacer plates and the spring plates will be replaced. Owner notification began february 5, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
L
lilfroger
5.9 CTD
Recall 01v037000: Throttle cable and upper bell crank lever
Nhtsa campaign #: 01v037000
make: Dodge
model: Ram
mfr campaign #: 970
component description: Vehicle speed control
begin date of manufacturing: 19930701
end date of manufacturing: 19960731
potential # of units affected: 157000
date owner notified by mfr: 20010803
report received date: 20010212
record creation date: 20010213
regulation part #:
Defect summary:
Vehicle description: Pickup trucks equipped with diesel engines. The throttle cable could unravel (fray) or break resulting in loss of throttle control.
A throttle that does not return to idle could result in unexpected acceleration, increasing the risk of a crash.
Corrective summary:
Dealers will inspect and replace the throttle cable and upper bell crank lever. Owner notification began august 3, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
L
lilfroger
5.9 CTD
Recall 01v038000: Abs sensor wire assembly
Nhtsa campaign #: 01v038000
make: Dodge
model: Ram
year: 2000
mfr campaign #: 971
component description: Service brakes, hydraulic:foundation components:hoses, lines/piping, and fittings
begin date of manufacturing: 19990708
end date of manufacturing: 19990903
potential # of units affected: 2000
date owner notified by mfr: 20010308
regulation part #:
Defect summary:
Vehicle description: Pickup trucks equipped with an anti-lock braking system (abs). Some vehicles may have inadequate clearance between the front tire/wheel and the brake hose/abs sensor wire assembly. During full lock turns, it is possible for the tire or wheel to contact the brake hose/abs sensor wire assembly.
This could ultimately result in wire damage and/or a hole in the brake line, affecting brake effectiveness, increasing the risk of a crash.
Corrective summary:
Dealers will replace the front brake hose assemblies, and the abs sensor wire will be inspected and replaced if necessary. Owner notification began march 8, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
L
lilfroger
5.9 CTD
Recall 01v040000: Hood latch
Nhtsa campaign #: 01v040000
make: Dodge
model: Ram
year: 1994, 1995, 1996, 1997, 1998, 1999
mfr campaign #: 973
component description: Latches/locks/linkages:hood:latch
begin date of manufacturing: 19930723
end date of manufacturing: 19990510
potential # of units affected: 701000
date owner notified by mfr: 20010917
regulation part #:
Defect summary:
On certain pickup trucks originally sold in or currently registered in the following "salt belt" states: Maine, new hampshire, vermont, massachusetts, rhode island, connecticut, new york, new jersey, pennsylvania, delaware, maryland, the district of columbia, west virginia, ohio, indiana, michigan, illinois, wisconsin, minnesota, iowa, and missouri. Corrosion of the return spring on the hood secondary latch could cause the mechanism to bind in the "release position."
consequence summary:
If the primary latch is not engaged, the hood could open unexpectedly.
Corrective summary:
Dealers will replace the secondary hood latch. Owner notification began september 17, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no.973.also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 01v119000: Front seat belt
Nhtsa campaign #: 01v119000
make: Dodge
model: Ram
year: 1999
mfr campaign #: 978
component description: Seat belts:front:retractor
begin date of manufacturing: 19981218
end date of manufacturing: 19990115
potential # of units affected: 161682
date owner notified by mfr: 20010820
report received date: 20010411
record creation date: 20010424
federal motor vehicle safety standard #: 209
defect summary:
Vehicle description: Certain van, wagon, pickup trucks, passenger and sport utility vehicles, fail to comply with requirements of fmvss no. 209, "seat belt assemblies." the front seat belt retractor may not comply with the requirements of the standard.
If the retractor does not work properly, it will not adequately protect occupants in the event of a crash.
Corrective summary:
Dealers will replace the seat belt retractor. Owner notification began august 20, 2001. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
L
lilfroger
5.9 CTD
Recall 01v153000: Airbag clockspring assembly
Nhtsa campaign #: 01v153000
make: Dodge
model: Ram
year: 1997, 1998, 1999, 2000, 2001
mfr campaign #: 982
component description: Air bags
begin date of manufacturing: 20000530
potential # of units affected: 216100
date owner notified by mfr: 20010618
report received date: 20010508
record creation date: 20010518
regulation part #:
Defect summary:
Vehicle description: Pickup trucks. Sound deadener material inside the steering wheel could become detached from the cover and housing. Note: The ram pickup trucks were built at the warren assembly plant ("s" in the 11th vin position) from may 16, 2000 through october 23, 2000; st. Louis north assembly plant ("j" in the 11th vin position) from may 19, 2000 through october 23, 2000; lago alberto assembly plant ("m" in the 11th vin position) from may 23, 2000 through october 23, 2000; and saltillo assembly plant ("g" in the 11th vin position) from may 23, 2000 through october 23, 2000. Important: Vehicles that have already had the proper clockspring installed, according to warranty records, have been excluded from this recall. In addition, 1997-2000 model year vehicles that have had a suspect replacement clockspring installed, according to warranty records, have been added to this recall.
When this occurs, the material could interfere with the clockspring ribbon and cause an open circuit. The driver air bag system will become disabled, and the air bag warning lamp will illuminate on the instrument panel.
Corrective summary:
Dealers will replace the clockspring assembly. Owner notification began june 18, 2001. Also some 1997-200 model year vehicles that, according to warranty records, have had a suspect replacement clockspring installed, will also be included in this campaign. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
L
lilfroger
5.9 CTD
Recall 01v184000: Lug nuts
Nhtsa campaign #: 01v184000
make: Dodge
model: Ram
year: 2001
mfr campaign #: 985
component description: Wheels:lugs/nuts/bolts
begin date of manufacturing: 20010511
end date of manufacturing: 20010515
potential # of units affected: 212
date owner notified by mfr: 20010604
report received date: 20010605
record creation date: 20010605
regulation part #:
Defect summary:
Vehicle description: Vans. A substitute wheel lug nut tightening process may not have been sufficient to assure proper torque of the lug nuts.
Improper wheel lug nut torque could allow a wheel to loosen and cause a crash without warning.
Corrective summary:
Dealers will inspect the wheel lug nuts for proper torque and correct if necessary. Owner notification began june 4, 2001. All owners have been contacted.
Recall notes:
L
lilfroger
5.9 CTD
Recall 02v042000: Alternator wire connection
Nhtsa campaign #: 02v042000
make: Dodge
model: Ram
year: 2001
mfr campaign #: B04
component description: Electrical system:alternator/generator/regulator
begin date of manufacturing: 20000101
end date of manufacturing: 20000828
potential # of units affected: 268740
date owner notified by mfr: 20020520
report received date: 20020207
record creation date: 20020211
regulation part #:
Defect summary:
On certain pickup trucks, the alternator wire connection to the power distribution center (pdc) can loosen.
This could cause a vehicle fire.
Corrective summary:
Dealers will inspect the installation of the alternator wire connection to the pdc and if necessary, reposition the wire so that the crimp connection will face upward and tighten the fastener to the correct torque setting. Owner notification began may 20, 2002. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no.b04.also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 02v159000: Rear axle flange
Nhtsa campaign #: 02v159000
make: Dodge
model: Ram
year: 2002
mfr campaign #: B20
component description: Power train:axle assembly
begin date of manufacturing: 20010701
end date of manufacturing: 20011130
potential # of units affected: 46000
date owner notified by mfr: 20021209
report received date: 20020613
record creation date: 20020613
regulation part #:
Defect summary:
On certain 4x4 pickup trucks, the rear axle flange weld to the axle tube could fatigue and allow the brake caliper assembly to rotate.
During rotation, the brake line could separate from the caliper resulting in a brake fluid loss in the rear brake hydraulic system.
Corrective summary:
Dealers will install rear brake caliper reinforcements on the rear axle assemblies. Owner notification began december 9, 2002. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no. B20.also, customers can contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 02v161000: Throttle linkage joints
Nhtsa campaign #: 02v161000
make: Dodge
model: Ram
year: 1997, 1998
mfr campaign #: B15
begin date of manufacturing: 19960701
end date of manufacturing: 19971231
potential # of units affected: 97500
date owner notified by mfr: 20020729
report received date: 20020614
record creation date: 20020626
regulation part #:
Defect summary:
On certain pickup trucks equipped with diesel engines only, the throttle linkage joints can corrode and cause the throttle to bind or stick.
This could potentially result in a loss of throttle control, increasing the risk of a crash.
Corrective summary:
Dealers will replace the rod ends and ball studs. Owner notification began july 29, 2002. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Also, customers can contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 03v077000: Mirror detent retainer
Nhtsa campaign #: 03v077000
make: Dodge
model: Ram 1500
year: 2002
mfr campaign #: C10
component description: Visibility:rearview mirrors/devices:exterior
begin date of manufacturing: 20010302
end date of manufacturing: 20030418
potential # of units affected: 195500
date owner notified by mfr: 20030410
report received date: 20030310
record creation date: 20030317
regulation part #:
Defect summary:
On certain pickup trucks, the detent system on the exterior mirror housings may lose the functionality.
This could potentially affect rearward field of vision, increasing the risk of a crash.
Corrective summary:
Dealers will install a mirror detent retainer kit to correct this condition. Owner notification began on april 10, 2003. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no. C10.customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 03v078000: Hvac blower motor circuit connector
Nhtsa campaign #: 03v078000
make: Dodge
model: Ram 1500
year: 2002
mfr campaign #: C11
component description: Steering:column
end date of manufacturing: 20020701
potential # of units affected: 287725
regulation part #:
Defect summary:
On certain pickup trucks, the electrical connector at the bottom of the steering column contains an under-sized terminal for the hvac blower motor circuit. Localized heating from current flow with the blower speed set on high may cause the terminal contacts to relax and lose electrical contact. This can cause the hvac blower motor to become inoperative.
This condition could cause impairment of visibility in inclement weather, increasing the risk of a crash.
Corrective summary:
Dealers will install a wiring harness overlay to correct this condition. Owner notification began april 15, 2003. Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no. C11.customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 03v504000: Snow plow package tires
Nhtsa campaign #: 03v504000
make: Dodge
model: Ram 1500
year: 2000, 2001, 2002
mfr campaign #: C40
component description: Tires
begin date of manufacturing: 19990701
end date of manufacturing: 20010731
potential # of units affected: 214
date owner notified by mfr: 20031222
report received date: 20031210
record creation date: 20031211
federal motor vehicle safety standard #: 120
defect summary:
On certain 4x4 pickup trucks equipped with the snow plow preparation package, the tires supplied on some vehicles may have gross axle weight ratings that slightly exceed the maximum tire load capacity as defined in federal motor vehicle safety standard no. 120, 'tire selection and rims for motor vehicles other than passenger cars.'
Corrective summary:
Dealers will provide replacement p245/75r16 tires to meet the load carrying capacity specified on the vehicle certification label and accommodate the addition of a commercially available snow plow and hardware. Owner notification began on december 22, 2003. Owners should contact daimlerchrysler at 1-800-992-1997.
Recall notes:
Daimlerchrysler recall no. C40.customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
L
lilfroger
5.9 CTD
Recall 04v185000: Abs control module connector
Nhtsa campaign #: 04v185000
make: Dodge
model: Ram
year: 1998, 1999, 2000, 2001, 2002
mfr campaign #: D20
component description: Service brakes, hydraulic:antilock:control unit/module
begin date of manufacturing: 19970701
end date of manufacturing: 20030630
potential # of units affected: 44588
date owner notified by mfr: 20040927
report received date: 20040412
record creation date: 20040420
regulation part #:
Defect summary:
On certain van and wagon vehicles equipped with 4-wheel antilock brake systems (abs), aftermarket batteries may leak electrolyte onto the abs control module connector, which can compromise sealing integrity of the connector.
This may allow development of a short circuit in the connector, which could eventually lead to a fire.
Corrective summary:
Dealers will inspect the abs control module connector for electrolyte damage and replace the connector as necessary. The recall will begin on september 27, 2004. Owners should contact daimlerchrysler at 1-800-853-1403.
Recall notes:
Daimlerchrysler recall no. D20.customers can also contact the national highway traffic safety administration's auto safety hotline at 1-888-dash-2-dot (1-888-327-4236).
Status
VLG6963
