3rd Gen Technical Service Bulletins
Status
Not open for further replies.
lilfroger
5.9 CTD
Technical Service Bulletins are put out by the manufacture to provide OEM service technicians with a procedure to resolve problems. TSB's are registered with the US Government and below is an export of that data.
To search for TSB's for your specific Year / Model please see: ODI - Office of Defects Investigation
The included information does not have step by step "how-to" or part numbers. It is simply a notification that there was a problem with a specific component.
TSB's are performed by Dodge dealerships for no cost if the component is still covered under warranty. For the most part if your vehicle is outside the bumper-to-bumper warranty the service will be billable. Some individual components have an extended service warranty due to a specific failure. Speak with your local Dodge service representative to check the status of your vehicle.
The "SERVICE BULLETIN #" or "REPLACEMENT SB#" numbers provided are provided by Dodge and should be searchable by your Dodge service representative.
L
lilfroger
5.9 CTD
Tsb 2200102: Chrome wheel
Service bulletin #: 2200102
replacement sb#: 2200101
nhtsa item #: 634082
date: 20020311
failing component: 980000 unknown or other
make: Dodge
model: Ram
year: 2003
date created: 20020927
description of summary: Chrome wheel care. *slc
L
lilfroger
5.9 CTD
Tsb 1801902a: Engine control module (ecm) from cummins
Service bulletin #: 1801902a
replacement sb#: 1801902
nhtsa item #: 634112
date: 20020904
make: Dodge
model: Ram
year: 2003
description of summary: Revision of flash process for new engine control module (ecm) from cummins. *slc this bulletin supersedes bulletin 18-019-02 dated june 17, 2002. *tt
L
lilfroger
5.9 CTD
Tsb 1802002: Flash programming failure recovery
Service bulletin #: 1802002
replacement sb#: 183298
nhtsa item #: 634272
date: 20020624
make: Dodge
model: Ram
year: 2003
date created: 20020928
description of summary: Flash programming failure recovery. *slc
L
lilfroger
5.9 CTD
TSB 1802402: Incorrect VIN number
Service bulletin #: 1802402
replacement sb#:
Nhtsa item #: 635689
date: 20020812
failing component: 355100 EQUIPMENT: OTHER : LABELS
make: Dodge
model: Ram
year: 2003
date created: 20021030
description of summary: Some 2003 vehicles equipped with dual rear wheels, built prior to july 15, 2003, may have an incorrect number as the sixth character of the vin. *tt
L
lilfroger
5.9 CTD
TSB 2100202: Diagnostic Prodcedures for Transmissions
Service bulletin #: 2100202
replacement sb#:
Nhtsa item #: 635721
date: 20020708
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2003
description of summary: Subject regarding revision in diagnostic procedures and labor operation times for re transmissions. *tt
L
lilfroger
5.9 CTD
Tsb 300202: Synthetic rear axle lubricant
Service bulletin #: 300202
replacement sb#:
Nhtsa item #: 635730
date: 20020701
failing component: 100000 power train
make: Dodge
model: Ram
year: 2003
description of summary: Information on the use of synthetic rear axle lubricant. *tt
L
lilfroger
5.9 CTD
Tsb 1400202: Tampering with vp44 fuel pump
Service bulletin #: 1400202
replacement sb#:
Nhtsa item #: 635734
date: 20020701
failing component: 070000 fuel system, gasoline
make: Dodge
model: Ram
year: 2003
description of summary: Information on tampering with vp44 fuel pump on cummins diesel engines. *tt
L
lilfroger
5.9 CTD
TSB 28: ENGINE COOLING FAN and PULLY
Service bulletin #: 28
replacement sb#:
Nhtsa item #: 10000331
date: 20021001
failing component: 062200 engine and engine cooling:cooling system:fan
make: Dodge
model: 2500, 3500
year: 2003
date created: 20030224
description of summary: Customer satisfaction notification to tighten the diesel engine cooling fan which may become loose and separate from the pulley. *tt
L
lilfroger
5.9 CTD
Tsb 2021: 5.7l engine valve spring breakage
Service bulletin #: 2021
replacement sb#:
Nhtsa item #: 10000442
date: 20021104
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram
year: 2003
date created: 20030227
description of summary: 5.7l engine valve spring breakage. *tt
L
lilfroger
5.9 CTD
Tsb 2022: Torque converter drain back valve
Service bulletin #: 2022
replacement sb#:
Nhtsa item #: 10000444
date: 20021126
failing component: 103700 power train:automatic transmission:torque converter
make: Dodge
model: Ram
year: 2003
description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve. *tt
L
lilfroger
5.9 CTD
Tsb 1400502: Fuel filter/water separator drain
Service bulletin #: 1400502
replacement sb#:
Nhtsa item #: 10000447
date: 20021108
make: Dodge
model: Ram pickup
year: 2003
description of summary: Fuel filter/water separator drain valve restriction. *tt
L
lilfroger
5.9 CTD
Tsb 1803502: Code p2181 - cooling system performance
Service bulletin #: 1803502
replacement sb#:
Nhtsa item #: 10000449
date: 20021129
make: Dodge
model: Ram pickup
year: 2003
description of summary: Engine throttle control light illumination and / or malfunction indicator light illumination with diagnostic trouble code p2181 - cooling system performance. *tt
L
lilfroger
5.9 CTD
Tsb 2024: Sticking pressure sensor transducer
Service bulletin #: 2024
replacement sb#:
Nhtsa item #: 10000620
date: 20021111
make: Dodge
model: Ram
year: 2003
date created: 20030325
description of summary: Harsh shifts due to a sticking pressure sensor transducer. *tt
L
lilfroger
5.9 CTD
Tsb 2026: Torque converter drain back valve
Service bulletin #: 2026
replacement sb#:
Nhtsa item #: 10000830
date: 20021220
make: Dodge
model: Ram
year: 2003
date created: 20030401
L
lilfroger
5.9 CTD
Tsb 33: Torque converter drain back valve
Service bulletin #: 33
replacement sb#: 222
nhtsa item #: 10000834
date: 20021201
make: Dodge
model: Ram pickup
year: 2003
description of summary: Customer satisfaction notification - torque converter drain back valve. *tt
L
lilfroger
5.9 CTD
Tsb 1: 3/8" torque converter drain back valve
replacement sb#:
Nhtsa item #: 10000913
date: 20030101
make: Dodge
model: Ram pickup
year: 2003
date created: 20030403
description of summary: Customer satisfaction notification - 3/8" torque converter drain back valve. *tt
L
lilfroger
5.9 CTD
Tsb 02026a: Restriction in the torque converter drain back valve
Service bulletin #: 02026a
replacement sb#:
Nhtsa item #: 10000914
date: 20030116
make: Dodge
model: Ram
year: 2003
description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve and may cause damage to the transmission. *tt
L
lilfroger
5.9 CTD
Tsb 1800503: Transmission shift/speed control improvements
Service bulletin #: 1800503
replacement sb#:
Nhtsa item #: 10001176
date: 20030307
failing component: 180000 vehicle speed control
make: Dodge
model: Ram pickup
year: 2003
date created: 20030417
description of summary: Transmission shift/speed control improvements. *jb
L
lilfroger
5.9 CTD
Tsb 800703: Accessory drive belt squeal
Service bulletin #: 800703
replacement sb#:
Nhtsa item #: 10001518
date: 20030404
failing component: 061110 engine and engine cooling:engine:gasoline:belts and associated pulleys
make: Dodge
model: Ram
year: 2003
date created: 20030605
description of summary: Replacement of the alternator support bracket for accessory drive belt squeal. *tt
Status
txram956
