3rd Gen Technical Service Bulletins
Status
Not open for further replies.
L
lilfroger
5.9 CTD
Tsb 14-001-10 : Dtc p0251
Service bulletin #: 14-001-10
replacement sb#:
Nhtsa item #: 10033546
date: 20100202
failing component: 092100 fuel system, other: Delivery:fuel pump
make: Dodge
model: Ram
year: 2003, 2004, 2005, 2006, 2007
date created: 20100823
description of summary: Dodge: Electronic fuel control actuator (fca) available for service/new diagnostics available for dtc p0251. Engine surges at idle or mil illumination. Further investigation may identify dtc p0251-cp3 pump regulator control-diesel. If p0251 is present, follow the diagnostics in this sb. If other dtc's are present, repair as necessary before proceeding further. Model ram truck. *pe
L
lilfroger
5.9 CTD
TSB-19-002-10: Steering Wander
Service bulletin #: 19-002-10
replacement sb#:
Nhtsa item #: 10033671
date: 20100123
failing component: 010000 steering
make: Dodge
model: Ram 4500, 5500
year: 2008
date created: 20100903
description of summary: Dodge: Steering wander. Involves selecting the proper repair procedure based upon vehicle build dates and then aligning the vehicle with revised specs. *pe
Status
RedFlameRam
