Hemi Motor TRQ Specs
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Here is the list for everything you need to TRQ your Hemi correctly
On a few its done in steps so its listed 1) 2) ect
Few of the bolts are also TRQ to yeild as the last step
Cam Gear bolt- 90 FT LBS
Timing Set bolts- 21 FT LBS
Rods- 1) 45 FT LBS 2) 60*
Mains M-12- 1) 28 FT LBS 2) 90*
Mains M-8- 1) 16 FT LBS
Main Cyclinder Head bolts- 1) 25 FT LBS 2) 40 FT LBS 3) 90*
Small Head bolts intake side- 1) 15 FT LBS 2) 25 FT LBS
Rocker Shafts- 195 IN LBS
Damper- 195 FT LBS
Exhaust- 23 FT LBS
Intake- 9 FT LBS
Lifter hold downs- 9 FT LBS
Oil Pump bolts- 21 FT LBS
Oil Pan bolts- 9 FT LBS
Front Cover- 21 FT LBS
Flywheel- 70 FT LBS
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Cross-post (I know) but chassis torque specs to have for reference,
here
RedFlameRam
