1990 ram v6 to v8 swap
Ram it!
Hello I have a 1990 4x4 dodge ram with a 3.9 v6. With a 4 spd manual transmission with a granny gear 1st the v6 has blown up and wanted to see what was involved or needed to swap from v6 to v8. Or if possible thanks for your help
88rambigblock
wv
1970 coded 440 big block
youre gonna need a v8, a wiring harness, motor mounts, probably a radiator, maybe a fuel pump... the conversion isn't for the lighthearted
Deblackmon3
South Carolina
LA 318
If you want a 318, I have one for sale haha. It works, but it would be best to rebuild it. I would rebuild it myself, but I don't have the money for it. It also came off of a 1990, so it should wire up without much difficulty.
You'll definitely want a new radiator though. The v8 takes alot more cooling power than yours probably can handle. Do you know how much pressure your cooling system is rated for?
crazzywolfie
under the truck
radiators are the exact same.
i am not sure about the motor mounts. on the 2wd trucks you need a special motor mount extension plate on the drivers side to stick a v8 where a v6 was. don't know if 4x4 are the same or not. i think you may also want to try finding a v8 wiring harness and computer. it may run with the v6 wiring harness and computer but i think the v8 has an extra sensor on the throttle body that the v6 does not.
Deblackmon3
South Carolina
LA 318
I just checked up on the sensor count you mentioned. Depending on how old the engine is, Chrysler implemented a custom fuel-injection system for the V8's from '88-'91 and the v6 Dakotas from '87-91. I can't find if the Dakotas were the only ones that received that upgrade or if it also was in the full size pickups as well. If I find any info on it, I'll report back.
crazzywolfie
under the truck
i know the v8's had some temps sensor on the back of the throttle body that are suppose to help with hot starts that the v6 did not have
R
Ram it!
So will my trans bolt right up to v8
DodgeAddict
Chambersburg PA
5.9 Magnum
The computer changes, the wiring can stay,fuel pump stays,the radiator will work(the shroud won't) the mounts will work on a 318 the drivers side changes with a 360 or use spacers to use it
Trans will bolt up with no problem
R
Ram it!
So I won't need the v8 harness. ?
R
Ram it!
And also will it matter if I use a newer 318 out of a 95-99 dodge ram ? Or do I need to use a engine from my series ?
R
Ram it!
Thanks for all of the help so far
DodgeAddict
Chambersburg PA
5.9 Magnum
If you want a Magnum the best way is to use a 92-3 W-D series complete wiring harness & basically a donor truck to do it easy
R
Ram it!
Ok. Maybe I could just go old school drop a 318 or 360 carb. And do away with the rest of what I don't need.
R
Ram it!
Idk tho. Just want a lil more umph under the hood. To haul what I want to... So just looking for easiest and most cost effective way to do so.
DodgeAddict
Chambersburg PA
5.9 Magnum
Here's a pic of the carbed Magnum 5.9 under the hood of my RamCharger using almost all factory made stuff to use A/C,serpentine & all
The Magnum provides a lot of cheap HP with a carb
R
Ram it!
Thanks dodge addict. Sorry for late reply. But all of the help I've got is great. Will i have any problems with pilot bearing hole on the crank I've got a donor truck with 318. So hopefully I can just swap engine and harness right into mine. With no issues
DodgeAddict
Chambersburg PA
5.9 Magnum
At worst you'll have to cut 3/8" off the end of your pilot shaft & use the adapter bushing designed for the swap where the crank isn't drilled for the pilot bushing
1Popeye
