Towing capacities
herooftheday
Hey all. New to the 1st gen rams. Just sold my '09 hemi and in the market for a D/W 250 for farm use. I cannot find the towing capacities for the engines that are available for first gens. I'm not wanting a diesel but I'm not sure the big step down to the 360 is going to be enough. I haul hay, cattle, tractors, balers and other equipment. Tractor alone is upwards 7500lbs without implements and trailer factored in. Anyone have input or put these motors to the test anything like I'm wanting to?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I don't believe anything gas is going to be of use to you.
You're going to need a Cummins and may have to turn it up a bit to tow the tractors.
crazzywolfie
under the truck
i don't see why a 360 would not be able to pull any of the stuff you mentions but it will be a pig on fuel doing so. if you are constantly using the truck for farm work you would be better off with a Cummins. they get great fuel mileage when not towing and get decent mileage when towing.
timpaine1
New york
3.0 l v6 diesel
I want to haul timber on my 14ft double axel equipment trailer the average timber weight is 6000lbs. can my truck handle this consistently my truck has a 4.7 engine and is regular with a factory tow package.
Rlaman
Ohio
We have been pulling a 7k camper through the hills of Ohio with a 93 with 410s and the 360 magnum. It does really well but 65 is pushing it. Otherwise does a great job.
1Popeye
