DIY: Differential Fluid Change
OlDirtyJohn
Naha-shi, Okinawa, Japan
2004 Quad Cab 2500 *Sold*
Heres a quick tut for changing out your differential fluid. Its not hard at all. So now you dont have an excuse to not do this at the recommended intervals.
Step #1 Gather proper tools and equipment.
You will need a 3/8" drive socket set, enough diff fluid of the proper weight, an oil pan, bucket, or something to catch the old fluid in, and some sort of heavy duty cleaner or degreaser (i used brake parts cleaner)
you might also need some RTV if you dont have a gasket on your cover.
Step # 2 Place drip pan under Diff, and start removing Bolts
You need to remove the bolts starting from the bottom and work your way up. This will allow the fluid to start draining without making a huge mess.
Step #3 Allow fluid to drain and remove cover
Wait a few minutes with only the top two bolts loosely in place for the rest of the fluid to drain out. Next remove your cover.
Step #4 Clean out pumpkin/cover and inspect Gears and Gasket
Using a clean rag wipe out all the excess fluid from the bottom of the differential. Use this time to inspect your gears for any abnormal wear or chips, or anything out of the ordinary. DONT USE CLEANER INSIDE THE DIFF!! you most likely wont be able to get it all out, and it could prematurely break down the viscosity of your new fluid. Next, inspect your cover gasket if equipped, and clean out the inside of the cover using the cleaner of your choice.
Step #5 Optional Step
If you have been wanting to get a new diff cover, but dont want to spend the money, you can paint the cover with a can of high temp paint and replace the bolts (I used grade 8 bolts, got them from NAPA), the results will surprise you! And it only takes a few minutes.
Step #6 Replace diff cover
Line up your gasket, or apply RTV gasket maker according to the directions on the package, and put your diff cover back on. torque down bolts according to specs. (in my case it was 30 ft/lbs) I also torqued bolts down in a criss cross pattern to avoid warping the cover.
Step #7 Fill Diff with Correct amount of fluid
To take out the fill plug simply use a 3/8" drive socket wrench. Next fill with diff fluid. (my 10.5" rear took 3 quarts) fill until fluid is just below the fill hole. Next replace fill plug, and torque to specs (24 ft/lbs)
Step #8 Stand back, and enjoy the fruits of your labor
Also, check for leaks. Those are bad.
korby05
Delta, PA
5.9 Magnum
What are the size of the bolts by chance? Is there any difference between the 1500 and the 2500 bolts other than how many you need
OlDirtyJohn
OlDirtyJohn
are you talking about the head size? or the thread size? i dont recall off hand. all i did was drive to NAPA, take one out, take it in with me, and find a match.
korby05
Delta, PA
5.9 Magnum
makes sense.. that's what I would have done anyways.. thanks again
PJF0455
I know this is an old post but I just changed my rear diff. fluid and the plug on the diff. cover is basically a rubber stopper. It fits pretty snug. Is this normal?
I have an 03 Ram slt 4x4 with the Hemi
Thanks
PJ
p.s.
Still getting around to updating profile.
PJF0455
Thanks
PJ
p.s.
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Yes. It needs to be to keep the oil from splashing out or pouring out.
PJF0455
Thanks
So the one in the Pic up top is rubber also?? Cause mine dosn't have the place for the wrench. I just pryed it out with a flat screwdriver. Was under the impression it was a bolt or sorts.
Thanks
PJ
BlackedOutHemi
DFW, Texas
2012 & 2012
His doesn't seem to be, may be an aftermarket cover. But mine is.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Factory ones are usually rubber stopper that is why I replaced mine in the event I got into some deep mud of water. I think mine was 20 or 30 bucks. Now I have a true plug.
$miley
sleepy hollow
Great Falls, VA
Great thread and great info.
2 Questions:
1. My 07 Laramie has a breather hose attached to the front differential? What is that about?
2. I have a fluid extractor that connects to my air compressor. Any reason not to use that for diff fluid changes? I understand the need to inspect visually every so often, but seems it would be convenient to use the extractor every other change or so? Any issues with this?
Thanks for your thoughts and advice.
OlDirtyJohn
OlDirtyJohn
yeah, you should be fine using a fluid extractor every other change or so. i know those covers are a PITA, especially when you need rtv.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
2 Questions:
I would not do it this way because the nasty stuff is at the bottom and you are leaving that behind. This is my reason for doing the long way.
$miley
PCA4208
Albuquerque, New Mexico
Quick question. Could I use the Red RTV sealant instead of the black? I have a lot of the red and it says its good to use on valve covers and oil pans. So I assume that it'd be fine to use with the diff cover right?
Chewy
Bettendorf IA
V8
It should be more than fine!
Sent from my iDevice using data nodes and algorithms.
PCA4208
Thanks.. I just got the black stuff because it was on sale. Doing the change now. Had a few setbacks like the spare is in my way and I almost completely stripped 2 bolts. Waiting for the rtv to dry before I can put in the new fluid now.
jsmith180601
How many quarts of gear oil did get to replace the old oil?
Sent from my HTC One VX using Tapatalk 2
jsmith180601
I got a 1500 so I believe its a 9.5 rear end
morgansamuel
