Trying to figure out what this part is!??
Powerddge1138
I took off my intake manifold cause the gasket was leaking coolant, so I thought while I had it off I'll send it to get power washed and sand blasted. Before they can sand blast it I had to remove everything off the intake well in trying to remove this part two of the nipples broke off and I can't find a new one anywhere! Please help me find one!
crazzywolfie
under the truck
if you don't need all the vacuum ports you could just plug them. otherwise you will most likely have to find a used one.
P
Powerddge1138
I found one in a junk yard! Now I'm trying to figure out what this plug goes Into? I've got it all back together accept this and it's bugging the crap out of me!
crazzywolfie
under the truck
but it still most likely has the plug for it. from the looks of the dirt on it it was not used anyway. if you really start looking around you will most likely find quite a few connectors that are just there for other packages that your truck may not have.
