guages pictures
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Hey guys I'm new to the 1st Gen world, post up some pictures of how your gauges are mounted. Also how do you remove the center panel in the dash?
RonJon '06
Southern Minnesota
Do you just want a pic of the dash from the outside or do you need one of what's behind the panel cause I dont have one with the panel off.
Redtruck-VA
Redtruck-VA
Virginia
I'm thinking of putting two or three gages in the center panel. So pictures showing gauges mounted and a little information on how to disassemble it would be great.
Thanks,
RonJon '06
Southern Minnesota
This isn't my truck since it's still stock but I found this in a search and thought it looked pretty clean. I looked for a DIY to go along with it but didn't see one.
f62a7fc5_zps79ccba96.jpg"]f62a7fc5_zps79ccba96.jpg[/URL]
3c6bb4e6_zps4e26657a.jpg"]3c6bb4e6_zps4e26657a.jpg[/URL]
IMAG0093-1_zps18587c85.jpg"]IMAG0093-1_zps18587c85.jpg[/URL]
DSC02442_zpsbd9a41dd.jpg"]DSC02442_zpsbd9a41dd.jpg[/URL]
Redtruck-VA
Redtruck-VA
Virginia
That looks awesome. Dumb question, how is the say radio or center panel removed from the dash?
RonJon '06
Southern Minnesota
That I don't know. It kinda looks like he just cut it out.:superhack:
This is what mine looks like. The rectangle on the left is for the 4WD indicator light, cubby hole on the right and radio underneath.
m0jbUGtTwu3tbeWg_n5_ajw_zpseedad604.jpg"]m0jbUGtTwu3tbeWg_n5_ajw_zpseedad604.jpg[/URL]
Redtruck-VA
Redtruck-VA
Virginia
I guess I'll have to pull the front and then make the insert plate(s). I'll probably remove the radio while I'm at it. Maybe have a spare dash face to work with and then just swap.
crazzywolfie
under the truck
here is the gauges i got on my truck. voltage, engine temp, tach, vacuum and out door temp. stock gauges suck for the most part.
Redtruck-VA
Redtruck-VA
Virginia
Yes, I'm thinking tach, boost, fuel pressure, egt. I specifically want a 0-3500 3-3/4" tach. I want to put it on the steering column. I've found a couple that use a flywheel pickup, but don't know if the harmonic balancer pickup will be a good substitute or is there a mounting arrangement that can be used with the flywheel pickup.. I think our flywheel(flex plate) is 152 teeth.
crazzywolfie
under the truck
ya i don't know much about that. i am use to dealing with a gasser lol. i am pretty good at making stuff work tho. i got a overhead console out of a 93 jeep Cherokee in my 93 and a OHC out out of a 93 caravan in my 81. if i can get some decent led light for the 98 caravan OHC that will be going in my 81 but having a hard time finding good leds for a weird light setup.
Redtruck-VA
Redtruck-VA
Virginia
Haha transplanting and modifying parts, very addictive....
Redtruck-VA
Redtruck-VA
Virginia
I'm starting to build a list of things I want to do to the Farmtruck. I need to get Redtruck back up into a support role ...lol
crazzywolfie
under the truck
after enough winter driving an overhead console with some good lighting might be on that list. stock cab lights on these things suck. there is a reason they are where they are on the newer vehicles.
Redtruck-VA
Redtruck-VA
Virginia
I don't like going out at night, the deer population is such that vehicles don't stand a chance.
crazzywolfie
under the truck
sounds like you need a catcher then. as long as the deer is not too big should do pretty good against one
Redtruck-VA
Redtruck-VA
Virginia
I hate deer. yeah a big a$$ push bumper might help..
Redtruck-VA
Redtruck-VA
Virginia
I had a California Highway Patrol push bars on my old 70 3/4 chevy. I wish I still had that bumper. Might have to build a replica...
crazzywolfie
under the truck
anything is possible with the right amount of money. i wouldn't mind building a custom front bumper for either of my rigs but i doubt i will ever get around to it.
VLG6963
