wheel swap
titifly
5.9 diesel
What newer style factory wheels are interchangeable with the 8 bolt from a 93 dodge 250? I was told the ford wheels fit,is that true?
crazzywolfie
under the truck
some for rims will fit but i think you might need spacers to run some of the newer style rims just because most of them have almost no back spacing.
cyclepuck
2014 2500 Mega
Yes the bolt pattern on the 8 lugs are the same from Dodge, GM and Ford. Here's a site that gives more info such as back spacing. http://www.myboltpattern.com/
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
On the 8 hole rims some 97+ won't fit over the rear axle hub.
