ADD has FOX shocks for your RAM
ADDCJ
cummins
let me know what you need, We carry the full product line!
Model Year Position Lift Part Number
Dodge Ram 1500 4WD 2002-2005 Front 0-2" 980-24-944
Dodge Ram 1500 4WD 2002-2005 Front 2-4" 985-24-021
Dodge Ram 1500 4WD 2002-2005 Front 4-6" 985-24-025
Dodge Ram 2500 4WD 2003-2011 Front 0-2" 980-02-773
Dodge Ram 2500 4WD 2003-2011 Rear 0-2" 980-24-945
Dodge Ram 2500 2WD 2003-2011 Rear 0-2" 980-24-945
Dodge Ram 2500 4WD 2003-2011 Rear 2-4" 985-24-022
Dodge Ram 2500 2WD 2003-2011 Rear 2-4" 985-24-022
Dodge Ram 2500 4WD 2003-2011 Rear 4-6" 985-24-026
Dodge Ram 2500 2WD 2003-2011 Rear 4-6" 985-24-026
ADDCJ
ADDCJ
cummins
for some odd reason FOX makes a rear for the truck, but does not have a direct bolt in for the front. I'll see what I can find for you guys
ADDCJ
ADDCJ
cummins
stock height? 220$ each
Mad Cow
Anchorage, AK
Cummins 6.7
These guys are going to make me go broke Kevin.
ramin44s
4.7 v8
Any shocks available for a 07 ram 1500 2wd with 7" lift?
ADDCJ
ADDCJ
cummins
do you have the CST lift on there?
I'm sure we can come up with something, I just need to know lengths.
Musclemckeester
Houston, TX
n/a
n/a
I'm running the Bilstein adjustable 5100s for the front. Unless FOX makes something adjustable for the front, I'm pretty happy with what I have. I was just looking to upgrade my Pro Comp shocks in the rear.
Hahaha
Oefootball_70
OLATHE
If I give you the length of the shocks and the attachments can you find me the FOX equivalent?
ADDCJ
ADDCJ
cummins
Fox does make a rear shock for your application.
Oefootball_70
OLATHE
Front shocks
Extended length 19.30 collapsed length 11.92 upper mount is S1 lower mount EB1 (see rear shock for info on the lower mount details.
Upper mount for front shock
the A column is the total length of the stud compressed, the B column is the length of the unthreaded portion of the stud, the C column is the diameter of the unthreaded portion of the stud, and the D column is the thread size. All dimentions are in inches except the thread size which is in inches with the pitch.
A- 2.37
B- .88
C- 3/8
D- 3/8-24
Rear shock
Extended length 26.65 collapsed length 15.94 upper mount and lower mount are eyeing bushings with the following measurements
EB1 mount details
In the table, the A column is the inside diameter of the bushing, the B column is the width of the bushing, and the C column is the compressed width of the bushing. All dimentions are in inches.
EB1
A- 5/8
B- 1.44
C- 1.25
This is the info I have got on the shocks for the Dodge Ram 1500 Roughcountry 6 inch lift.
Let me know if there is anything else I can dig up for you guys. I really would like a set, just afraid of the cost!
Thanks for the help in advanced.
ADDCJ
ADDCJ
cummins
Front shocks
Rear shock
2wd or 4wd? lifted?
Oefootball_70
OLATHE
Yeah 2wd lifted with rough countrys 6 inch suspension lift, thanks Scott
Oefootball_70
OLATHE
Yeah they were able to get me set up with what I wanted by me giving them lengths and attachment style and size of the shocks. I just didn't realize the price of Fox shocks. I'm too broke right now to do something like this. Hopefully one day!
