2015 Tuning
hemifever
Apex, NC
I have tuned a 2015 5.7 Ram and it seems to respond much like the 2014 models. Tuning is much quicker on the '15 as it doesn't take 30 min to download the backup file (maybe that's due to the different ECU).
For now, and maybe forever, it WILL take a 2nd ECU. I have the ECU/Tuner packages setup but I don't expect shipping availability for another week. Its really close though. The benefit in the 2nd ECU is there's no need to restore stock files when going to the dealer. Swap the factory ECU back in within a few minutes time.
these prices do include the extra tuning services. Here are the links for ordering:
Trinity and ECU : https://www.hemifevertuning.com/ProductDetails.asp?ProductCode=DSP-Trinity-2015
i2010 and ECU : http://www.hemifevertuning.com/diablo_intune_dcx_p/dsp-i2010-dcx-2015.htm
CMil527
Old Bridge, NJ
2021 RAM 1500 LARAMIE-CC
Thats not a bad deal at all... nice job!
Northshoremb
Banned
Still more then $400 for the intune by itself and same HP
Sent from my SM-G900W8 using Tapatalk
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
This is exciting news.
I know a lot of 2015 guys that have been begging for this day to come.
H
hemifever
Apex, NC
In one aspect it is going to suck to have to purchase a 2nd ECU that's unlocked but I've not seen any progress in unlocking the factory unit using a tuner (of any vendor) at this point. I guess one good thing is you don't have to worry about warranty issues crapping out your factory one while tuning, or having to worry about a dealer noticing anything has been altered on the factory pcm. You can swap back to the factory pcm in less time than you can re-do all the tuning.
myoung84
Tulsa, OK
2012 Power Wagon
What about the difference in mileage between the instrument cluster and the pcm? Isn't mileage stored in both places?
H
hemifever
Apex, NC
The new ecu will be VIN flash, mileage flashed, and setup with your factory calibration. As for the factory ecu, its mileage will stop. however, the cluster doesn't receive its mileage from the ecu so that always stays accurate. I've never seen a dealer try to match mileage in the pcm to the cluster (to this date)
AlwaysSomethin
2015 Ram
5.7L
Wouldn't that make the fact PCMs have been swapped incredibly apparent if you swap back to stock and milage is stored both places?
Edit: I think you added to the post as I quoted it LOL
So you've never seen them compare the milage of the 2? I'd think that'd be the first think they did if you had an engine issue.
H
hemifever
Apex, NC
its rare that I see dealers on a witch hunt looking for a tune. Most don't know how to gather the right info anyway. I always recommend finding a mod friendly dealer. any dealer that targets pcm changes is gonna do the same with cai's or exhaust too. Even the factory ecu will show how many resets it has. If you retune 15 times it'll show 15 resets. But dealers don't look for that either. I guess IMO, having the 2nd ecu is safest as going in with an ECU issue on the factory one once its tuned has the most chance of being flagged as a voided service claim.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Brutal. If you have more money then brains do it
Not sure where that mind set is coming from. What other mod can you add for $1000 that will get you 30-35hp/tq to the rear wheels? Intake is about $300, throttle body is about $350, muffler swap is about $200. There is your $1000 for maybe 25-30hp to the wheels. Longtubes alone are going to run you $850-$1700 in parts alone for the same 25-30hp.
Yes, this is about $500 more than it used to cost for the same tuner, but it is the only way to get it done on a 2015 model. Believe me, Diablo is the one taking the hit here by offering them at this price. Go look up the cost of a brand new PCM from Dodge, and you will see that they are basically giving the tuner away for free at this pricing.
If you enjoy driving a stock truck, then have fun with it. For anyone that wants to go faster, pull their trailer easier, or get better mileage than they are getting now, then this is your best option.
Dimarini
I just installed SW Long tube headers, Magnaflow exhaust, 180 degree T-Stat, 87mm ported TB on my '15 Ram Sport ... so I NEED a tune. Chompin' at the bit :)
GardysGarage
Is there a preorder/group buy getting put together? I know you mentioned it in your first post. Thanks
AlwaysSomethin
2015 Ram
5.7L
Hypothetically speaking, what If I happened to already have an extra 2014 RAM PCM? Lol
H
hemifever
Apex, NC
I haven't seen a 2014 style setup with correct VIN to know how compatible it is.
Kenneth1977
2016 Limited 4x4
So can i still use my i1000 that i had for my chevy ? If so can i just buy the PCM or is it only a bundle deal ?
