1500 air bags
Devin1349
What is up you guys, after reading comments from my last thread (1500 tires) i got to thinking about air bags. i found some online for $82 on SDtrucksprings.com and im a little worrried from the saying you get what you pay for. so what do you guys think about these air bags or leave comments or reviews of what you guys use with a link address for any suggestions. GUTS GLORY RAM
thrashie
All Over
2013 2500 Laramie
6.7l cummins turbo diesel
I had airlift 1000's in my 1500, they did awesome, no issues in the 3.5 years I had/used them. I think they were only around $100 and pretty easy to install.
Devin1349
Devin1349
Do they make the rear end look higher because as these rams already look like the rear end is higher already
Padilen
I've had mine a short time, worth it. Less than 100$ for them, if you hate the squat with a light load.
Devin1349
Devin1349
awsome i think this will be my first modification followed by a diablo intune tuner
Jimmy68
Lethbridge Alberta Canada
5.2L Magnum
The rear does not sit higher. Unless you fill them while your unloaded.
If you fill them after your loaded you can just level your truck or even raise it some.
Mine can raise the back two inches over stock empty or loaded.
pcschwenke
I added the Firestone kit with jounce bumpers last year. The truck sits an 1" higher with 15lbs of air. They definitely help while towing.
OUMX117
You are supposed to fill them before you load them. If you fill them first the truck most definitely sits higher than with them empty.
Jimmy68
5.2L Magnum
You could do it that way. Geuss you want 50Lbs in them and only needed 20Lbs. Or put 20Lbs and needed 50Lbs.
You could just fill them to shop air pressure and let out air till you get the level you want.
I usually fill after I've loaded.
You know, pull the trailer to where I need to load it. Load it, then fill till it's good. Unless no air nearby like a car on the highway, then fill till truck stops going up and call it good. Rough ride but sits good once vehicle is loaded.
I never look at how much pressure I put in.
Will1972
Aubrey,Tx
5.7 HEMI 3.92 GEAR
I have the Firestones. Max pressure 35psi each (I usually run 34, easier to see on the gauge). Lifts the truck about 2 inches empty. Sits level with our 9000 pound trailer. Manual says to fill them before you put a load on them. No issues with them except I had a valve stem core back out enough to lose air in one. tightened it up, good to go.
Jimmy68
5.2L Magnum
Good stuff to know. I have bags that were there when I bought it. I can and have put up to 50psi with no issue. I have loaded 2400Lbs (220 gal water tank) on the back of my 1500 and it holds just fine.
I fill before I load if I do that.
I am thinking about on board air and hooking the bags to a level valve so I never have to fill again. Just load and it will self level.
