would like to purchase the factory controller put i am hearing horror stories from ram owners saying it not set up for the factory controller how can i find out if my truck has the the two four plugs under the dash
If you lay on your back and look under your dash there is a big harness wraped in black loom near your parking brake pedal.
Taped to it there with either be 1 or 2 wiring plugs. If you have both your golden. If you only have one there is an adapter harness you can buy and splice in to provide power.
Here is a picture off an ebay add for the controller.
Mine were tapped about 6 inches apart from eachother, but the picture shows then closer. Sorry there small.
