20 in stock rims P275/60R20 BSW Towing
wolfskinner
I just purchased a 2112 Ram 4x4 Reg cab 8ft bed with P275/60R20 BSW All Season tires. (Came with the package deal). Truck has 3:55 anti spin option.
Do these tires lower the 8500# tow limits set by dodge?
I may pull a 7500# (loaded horse trailer) on the rare occasion my F250 breaks down. Generally I would be pulling a 3000# boat.
Knotts89
Montvale, Va
Welcome to the forum. Lots of knowledge here I'm sure someone will be able to help you out.
GoldDot
Tow rating is based on your gears. 3.92's have the 10,000 lb rating.
You dont need to worry about the 20's unless your going to exceed the rated towing/static load for your reciever by going to an aftermarket set-up.
Even the 20's are rated for around 2600lb each with the truck at around 6100 lb.
With that being said if I towed on any regular basis, load range E 17's would be on mine.
W
wolfskinner
Thanks for info to all.
Its just a piece of mind thing with the 20's. Never owned them.
I run e rated 17's on my F-250 which is a 460 with 4:11 (which gives me 7 mpg) .
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Not to be that guy but the rating has other factors when they decide the rating.
-The transfer case such as with 4WD auto is rated slightly less than 4WD case without auto 4WD option.
-Gears 3.21, 3.55, 3.92
-The tires that come on a 1500 are only P series tires so they really are not very great for towing.
If you go to the website there is a configuration wizard that allows you to see what things change the rating.
I am sure you can tow more that 10000 lbs but it would not be legal :)
$miley
garner
Harker Heights, TX
Max tow is 8,750 for your truck but with 17's according to the ram website. They don't list the weight for 20's though. I believe 7,500 should be perfectly fine
Only wheels that supposedly really lower the tow rating are the forged 22s on the R/T
my09hemi
Piscataway,NJ
I got rid of the goodyears-horrible overall-2695# per tire-max 44psi and replaced with Cooper HT Plus-2995# per tire-max 50psi-very happy for the past 16000 miles.
dsw1519
Bucks County PA
2013 Laramie CC 4x4
HEMI 5.7 8 Spd.
Did you know any change to your gas mileage with the tire change?
