RoadDog66
Considering a 5th wheel that's 9500 lb dry with a dry pin weight of 1625. Anyone with the 6.4 Hemi towing a similar weight 5'er? (I do have 3.73's)
I think when you start to reach the max tow capacity (or a few thousand under it) on ANY truck things start to get difficult. The trucks can do it for sure....but its not comfortable doing it and neither are you and you will need to buy a lot of "towing helpers" to make it safer (air bages, WDH...yada yada).
I wouldn't expect anything different.
If I was planning on towing 12,000 lbs I would be getting a cummins without hesitation. its just safer.
JMO
I'm only looking at most being at 10.5K lbs completely loaded up for a week long trip. I'd never attempt more than that with my ratings. It's odd that the pull behind towed better for you. As i mentioned everyone has told me 5'ers are a much better tow since the weight is in the bed, but "grain of salt" right.
I know a CTD would be preferred, but not in the cards anytime soon. I appreciate the feedback from all of you. I might just deal with the slow towing for a bit then see what diesels are about.
9500 is doable but remember that is not all the weight of the combined vehicle, which is what your truck is rated for.
You are under the GCVWR with 9500 and a reasonable load in the trailer and the truck. But you do need to know what everything weights.
I noticed on buying the Ram that it shifted differently than my Titan, but at first figured it was just a 6-spd vs 5-spd trans. My Titan towed that same 7K+ lb travel trailer pretty well and accelerated thru all gears without a hiccup. First trip with Ram towing it, the torque mgmt reared its head and required some getting used to. I posted early on in my time on the forum about it.
That was about the same tow rating difference for both the Titan (9600 max w/ 7+K trailer) and the Ram will have (12,600 max w/10+K 5'er). The trans are just totally different, but I know the power is there. I just use the manual shift button and leave the tow/haul mode off. We'll see in a few weeks how it plays out.
I travel with a bit of water but usually no more than 15 - 20 gallons, just in case.
With the pin weight, firewood, passengers and fuel weights; you should be good. It all depends on what goes in the trailer, too.
I considered a Cummins but my 5'vr empty weight is 8250# so I generally don't have a problem with towing it and the gear we take. It does get a bit slow on some of the 6% grades we haul over around here but I'm working on a "more power" plan now.
Let me know how the "power plan" goes...might be cheaper than a trade in down the road
The Tow/Haul will change the shift points of the trans, it also changes the cooling strategy for the trans and enables the Trailer Sway Control.I just use the manual shift button and leave the tow/haul mode off.
Mto, so you're saying the 66rfe is more the problem than the 3.73s? I'll have a few longer grades to climb in my area, but nothing too crazy. Typically in 4th at steady pace up the grades & 3rd to pass with my current trailer.
I thought there were a few guys towing heavier 5th wheels on the forum w/out issue. 9500lb just doesn't seem like it should be too much for our trucks.
