adboyd06
- Mar 9, 2016
- 157
- 57
- Rochester Hills, MI
- 2016
- Diesel 6.7
I have decided to purchase the Air Lift 1000 to help with rear sag when hauling and I have three questions:
1. Is it best to run the T air line routing or dual air line routing? Positives and negatives for both?
2. How long does it typically take to deflate both air bags back down to 5 or 10 psi after being fully inflating to 35 psi? Does anyone install a dump valve (or something similar) to deflate faster?
3. Is it necessary to wrap the air lines in anything for added protection, if so, what do you recommend?
Thank you. Truck is leveled with Bilsteins at 2.1. Broke up a 8'x10'x4" concrete slab, took three trips to the local dump. Now for some pictures:
Adam
Adam
