save yourself ! removing the rear coils is a ten min job !
1 jack truck up from rear punkin/ two jack stands under frame
2 remove rear tires
3 remove lower shock bolts
4 remove upper sway bar bolts
5 lower jack to the point the springs fall out but not as far as getting the brake lines tight..
If you have basic tools and a garage floor doing this will take less than a 1/2hr ..
I have a shop and it takes me ten min to have the rear coils out .....
2 remove rear tires
