IdahoLonghorn
After looking through old threads I think I have a different problem with my factory controller. I just restored an old horse trailer including putting a new 7-pole plug on it. When I was installing new lights, etc, I used a MUTT trailer wiring tester and everything was working perfectly including the electric brakes. Other than the lights and new plug I did not touch the original wires. Before I replaced the trailer plug (because the housing was cracked) the brakes still worked fine. When I plug it in to my truck, intermittently I am getting warnings such as "trailer brake not connected" or "check trailer wiring" etc. During this time all of the trailer lights continue to work perfectly. It will often go back and forth while driving down the road, as if a wiring connection is loose but the connection remains tight. After cleaning the truck and trailer plug I hooked them up, jacked the trailer up and tested the brakes, and they worked fine. When I drove away I received the warnings and the trailer brake was said to be "disconnected. I took the truck and trailer to a local garage, he tested everything, looked at the plug wiring inside the housing as well as the wiring harness on the truck side and he was stumped. The trailer worked fine on a tester, the truck plug brake pin is putting out power. I got it home pulled the wheels off, checked the brake ground wires. Although they appeared tight the screws were rusted. I unscrewed both, drilled new holes and reconnected the ground wires with rivets. I tested the brakes before putting the wheels back on and they functioned perfectly. I hooked it up to the truck for a while, everything was connected and acting normally. When I pulled the trailer for a test drive today the warnings came back and the trailer brakes were "disconnected." Last week I rented an old trailer with electric brakes to haul a tractor and it worked fine, no issues. I don't know where to go with this now. I am going to buy another trailer plug, different model, and see if it changes. This horse trailer worked fine before I put this new plug on. I have an appointment with the Dodge dealer in a couple weeks to deal with the T25 recall. Is there a software update for the ITBC? The bumper to bumper warranty has expired, so if it is going to be cost prohibitive to fix the ITBC I'll just put an aftermarket controller in, begrudgingly. To top it all off the trailer works flawlessly with my wife's 2013 F-150. The only think I can think of is that the RAM's ITBC computer is so damn sensitive that it just doesn't like the new trailer plug and shuts the system down.
Any ideas?
Any ideas?
