Another brake controller question but on a v6
cspaid
2013 ram 1500
Just bought the 2013 ram with the 3.7 and 8 speed tranny. I pull a 27ft camper at 5700 pounds all day no problems. I would like to install a brake controller but dealers and forums are all telling me different things. Im not sure if the v6 is different but the plug people are showing me doesnt match anything i find under dash. Can someone actually post a pic of the harness and location hooked to their truck please.
Thank you.
GETARAM
Edson, AB
under the driver footwell panel on the right are two plugs (gray) all wrapped up with foam/tape. non factory brake controllers require a pigtail adapter sold at rv shops, or you get the mopar one installed and still have trailer sway control and whatnot working through your computer
C
cspaid
2013 ram 1500
So i have to pull the panel next to gas pedal?
GETARAM
Edson, AB
nope just cram in there and look up and reach in above where your shin is, theyre in there
C
cspaid
2013 ram 1500
Found them thanks. So is it better to have the factory one or an aftermarket?
redneckstylin
Prince George B.C.
pentastar
Sent from my GT-I9100M using Tapatalk 2
GHQ
pentastar v6
Towing your 5700lb trailer
Hello
I'm considering purchasing a 2014 Ram with the Pentastar. I curious what your fuel economey while towing your 5700lb trailer. Mine is 5200lb so it should be close.
Thanks
electricme
Douglassville PA
Figured Id post this in this thread... I pulled my camper the other day and used the brake and harness from the 2010 bighorn... it plugged in ok but the brake always had the brakes on? on the 10 i could adjust the gain or whatever when I push the brake it would apply the brakes that percentage on the trailor for this I had to turn it all the way down and use the E brake... Has it changed from 10 - 13? and the plug fit so I assumed it was the same.
Power Wagon
Sunshine State
I don't know if you've solved your problem but figured I'd post this video of the install for your truck :
Trailer Brake Controller Installation - 2013 Dodge Ram Video | etrailer.com
I also noticed this reply in the e-mail troubleshooting section (discussing the wiring change to 2013 and up RAMs) :
Wiring Change in 2013 Dodge Ram 1500 Pickup Affecting Aftermarket Brake Controller Installation | etrailer.com
It appears you need the proper wiring harness (3023-P). According to the videos, it should then work properly.
From the E-trailer site : "Although the under-dash connection port (on the 2013-and-up) appears identical to earlier model years the assignment of the functions on the various wires has changed. The terminal that used to be the stop light signal, now has battery voltage whenever the ignition is in the run position."
fla crkr 1 ton
Palm Harbor Fla.
5.9 [360]
I'm in the trailer business and we have found that the Ford and GMC and some Dodge trucks with the factory installed [built in] controllers have issues when using electric over hydraulic disk/drum brakes, when using straight electric drum brakes everything works fine, however when towing a trailer with electric over hydraulic brakes the brakes don't work, I have read that the newer trucks controllers don't receive a resistance signal from the magnets in the brakes [because there are no magnets] so the computer thinks there is no trailer hooked up and no power is sent to actuate them. You need to install either of these items in your tow vehicle to fix the problem.
Titan BrakeRite SD Adapter for Ford/Chevy Integral Brake Controllers Titan Accessories and Parts T4845900
CARLISLE Hydrastar Controller Adapter Module #HBA-CAM
These will fool the controller into thinking it has magnets and the system will work.
THIS IS ONLY FOR FACTORY INSTALLED [BUILT IN] CONTROLLERS, AFTERMARKET UNITS WILL WORK FINE WITHOUT THIS UNIT.
therapywolf
