NewBlackDak
- Feb 9, 2014
- 1,083
- 654
- 2014
- Hemi 6.4L
I tow with a 1500 hemi and yes e rated tires make a YUGE difference. Its night and day with stiff sidewalls and some more air pressure.
Anyway the OP needs a better hitch also. If you have bars with chains there is little sway control and the friction bars are crap.
I have had a reese dual cam in the past with a single axle trailer using a short wheelbase wrangler for a tow vehicle and it was properly set up and worked great.
I now have an e2 hitch that has the bars that ride on steel pads and I get no sway and I am at max payload fully loaded and combined weights. Yes I have CAT scale numbers. This 1500 tows great and its not a white knuckle experience. It is set up so I have weight on the front axle and proper weight on the tongue.
It was amazing how much better it towed after I went to the CAT scale and weighed loaded and then empty from my starting point. Then I made adjustments to the weight distribution bars (mine double as the anti-sway friction device) and the front axle got its weight back and it tows great.
So 1500's are very capable if even at the maximum capacity ratings but you have to spend time on a complete setup for the hitches and you have to have a hitch that actually can dampen sway and keep the trailer tight to the vehicle.
Did you upgrade wheels with tires? Many if the crappy stock aluminum wheels found on 1500s won't hold up to the pressure of higher rated tires and crack.
