So it is better to plan for the snow where you can turn down the gain vs having the voltage be too low at all times and have your trailer push you through a intersection? Sounds to me like the are catering to idiots who don't know how to set the gain under inclement conditions by keeping the output low at all times.Okay I received the explanation of how the brake controller is to operate from Chrysler. Some of you may already know this or this may have been explained before I dont know. Here it is see below.
I'm speechless after reading the explanation. OK, not totally speechless. The purpose of proportional braking is for the TV and trailer to slow at the same rate and begin braking at the same time.
As far as not being able to read the voltage of a PWM signal, the person that wrote the explanation likely doesn't not have any education in electronics or experience with DC circuits. Any DVM will read the equivalent DC voltage of a PWM signal.
Frustrating!
If they give the bs about a multimeter not being able to read it someone at the dealer would have an oscilloscope that would show the entire waveform that would show the true voltage and frequency.What about the DTC that i posted and is stored on my truck : C10C6-92 . I was away . Havent had a chance to call ram yet.
I think they are all just reading from a manual/told what to say. They want to avoid the issue cause the pwm voltage changes so they use that as an excuse and say you cant measure it cause the voltage is constantly changing. The "tech" at my dealer gave me the same bull saying its a pwm signal so u cant measure it accurately with a dvm. Its a little over my head But....shouldnt it remain a constant Approx. 12v with gain kept at 10 and slider at 100%. Just like a light dimmer that uses pwm right? If the dial is all the way up its going to show the same voltage, if its at 50% or half way, the voltage will change but it will still be the same at 50% every time, and so on.....Is this correct
So.....did you show the scope results to your dealer? It looks like you have everything you need as proof, even trailer brakes tested. Should I request they do the same test like loveracing said above that you did? It seems pretty obvious from the scope reading. Or are they just telling you that they have to do what ram tells them like my dealer told me? By the way, I also have 2 dexters that are 7k . BTW, what the heck is that video of the car tire blowout?
Dammit.So we have 4 options:
1) keep trying to find someone to listen
2) replace with aftermarket
3) wait till someone gets killed or in a major accident
4) get rid of the truck and let someone else get killed or in accident
I dropped my 2500 off yesterday for a few things including the Trailer Brake. I also notices right away that it did not seem to be working right. I tow a 9000lb travel trailer. I kept turning the gain up, and it seemed to have no effect. I will let you know what Farrish Ram in Falls Church, VA has to say about it.
I'll tell u exactly what they're going to say: "working as designed"
and if they do tell you that, which is about all they ever say anymore, ask them how they determined that? That will get them going.
For me, it is working as designed because they hooked a blower motor to the brake controller wire and the motor turned
Just a thought but has anyone contacted these guys about this they are also in Colorado?
TFLtruck - Hall of Ike Gauntlet - Truck News, Views and Real World Reviews
What years is this impacting
