htxdc
Greetings all! I'm interested in this travel trailer, 2014 Gulfstream Streamlite Champagne 29BIK. Weight and Dimensions of the RV below:
Dimensions:
Length 34.42 ft. (413 in.)
Width 8 ft. (96 in.)Height 11 ft. (132 in.)
Interior Height 6.67 ft. (80 in.)
Weight
Dry Weight 6,674 lbs.
Payload Capacity 2,986 lbs.
Hitch Weight 920 lbs.
I have a 2012 Ram 1500 Crew Cab 4x4 5.7L 3.55 gears, 8500 GVWR. I'm currently running stock Wrangler tires, no lift or level. To make this work I know I would definitely need E Rated tires (currently looking at 275/65r20 tires) and Air Suspension/Tuff Truck Springs.
As always, thank you guys for the help!
Dimensions:
Weight
