Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Towing & Hauling
Towing & Hauling
Difference between 3.21 and 3.92 Axle Ratios
This is a discussion on Difference between 3.21 and 3.92 Axle Ratios within the Towing & Hauling forums, part of the 4th Gen : 2009 - Present category!
I'm about to get a 2014 1500 LoneStar with a 3.21 Axle Ratio (sweet deal for $23,000 with 19k miles). ...
Like Tree19Likes
Reply
Old 12-06-2016, 10:33 AM   #1 (permalink)
Ram Year: 2014
Engine: 5.7L Hemi
Default Difference between 3.21 and 3.92 Axle Ratios
I'm about to get a 2014 1500 LoneStar with a 3.21 Axle Ratio (sweet deal for $23,000 with 19k miles). Only problem is that it has the 3.21 axle ratio.
Question: Does it make that much of a difference? Some charts I'm looking at are giving me a 500lb pulling capacity difference, some are giving me 2,000lbs.
I'll own a small utility trailer dealership and although most of my trailers are delivered to me, I'll be pulling a stack of 3-4 trailers 2-3 times per month (8,000 lbs is the most I'll probably pull) on flat terrain (I'm in N. Texas).
Sponsored Ad
Register to remove this ad.
TruckNoob is offline   Reply With Quote
Old 12-06-2016, 11:20 AM   #2 (permalink)
Ram Year: 2015 Power Wagon
Engine: 6.4 Hemi
Default
need more info on the truck to determine a max tow capacity. considering crew cab 4x4, 8000lbs could already be pushing it (legally). the difference in tow capacity between the two gear ratios is in fact around 2000 lbs. 3.21 to 3.92 is a big difference. whether or not its important to you, thats something your going to have to determine.
DannyMK2 is offline   Reply With Quote
Old 12-06-2016, 11:27 AM   #3 (permalink)
Ram Year: 2014
Engine: 5.7L Hemi
Default
Thanks for the response. It is a 4x2 Quad Cab w/ a 6'4" Box. I'll be using a weight distribution hitch and am looking into whether or not to put in an air bag suspension kit and the such.
I really wish it was the 3.92, but I don't think I can pass this up at the price.
Old 12-06-2016, 11:29 AM   #4 (permalink)
thrashie's Avatar
Ram Year: 2013 Ram Laramie
Engine: 6.7l cummins turbo diesel
Default
RAM Trucks - Towing & Payload capacity
click on the red box "lookup my vehicle" on the right side of yer screen, plop in yer vin, and yer in the know of how much u can tow!
came in handy while I was at dealerships looking at used trucks, same with the window sticker lookup site as well. super handy to see all the options the truck shipped with. just change ADDYOURVINHERE to your vin.
http://www.chrysler.com/hostd/window...ADDYOURVINHERE
R.L.K. likes this.
__________________
2013 Laramie CC, 6.7 CTD, 4x4 White
2012 Charger R/T Max
2016 Prime Time Tracer 3150BHD
thrashie is offline   Reply With Quote
Old 12-06-2016, 11:41 AM   #5 (permalink)
Engine: 6.4 Hemi
Default
an 8000 lb trailer is going to put you right at max capacity. are you comfortable with that? if i had to do that 2-3 times a month, id probably re-consider my purchase.
R.L.K., dRAMbuie and lonestar21 like this.
Old 12-06-2016, 12:14 PM   #6 (permalink)
Ram Year: 2014
Engine: Hemi 6.1
Default
The warm fuzzy feeling you get from finding a great price will fade long before the regret of not getting what you really want. That 2000 lb cushion is worth a few extra bucks.
Bigdaddy and R.L.K. like this.
bobeast is offline   Reply With Quote
Old 12-06-2016, 01:01 PM   #7 (permalink)
Ram Year: 2014
Engine: 5.7L Hemi
Default
You guys are killin me. I was so sold and set on that truck. Now I'm seriously reconsidering. Its now a matter of whether or not I get the 3.92 or just decide to pull smaller 6500lb loads.
Thank you for the advice! I've been on these forums a lot the past week or two as an observer. I really look forward to being a part of the community.
R.L.K. likes this.
Old 12-06-2016, 02:13 PM   #8 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default
I have a 2016 1500 5.7 crew cab 4x4 with 8 speed and 3.21 rear. I tow a 26 ft travel trailer weighing 6000 lbs loaded with no problems.
It tows better than my 2012 did with the 6 speed and 3.55
UDCentaur likes this.
coldfusion73 is offline   Reply With Quote
Old 12-06-2016, 04:58 PM   #9 (permalink)
Ram Year: 2014
Engine: 5.7L Hemi
Default
Ok, while doing more research it looks like I can just get new gears put on for under $1000. Is it as simple as that?
Old 12-06-2016, 05:11 PM   #10 (permalink)
Ram Year: 2016 Ram 2500 Crew Cab
Engine: Cummins 6.7
Default
Pulling the trailer, yes. Legally no. Legally no matter what gears you put in it the truck is still rated for the original rating. But, the truck you were looking up will pull that 8000 pound trailer with no problem even though you're at the limit. Why not shop for a 2500 and then you'll be safe all the way around. I pull a 7300 pound trailer with my 1500 with 3.21 gears, I have pulled from Georgia to South Texas with no problem. I can tell though, with handling, the truck is pushing it.
muzupan is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Differential Ratios Hemibound General Discussions 3 10-16-2016 06:20 PM
axle shaft difference? ramburger General Discussion 4 06-24-2015 08:57 AM
Gear Ratios 01bigblue Lifted 28 03-24-2014 12:06 PM
Gear Ratios fuelman99 Engine & Performance 16 10-30-2010 01:03 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
