RangerGress
- Mar 9, 2014
- 106
- 33
- Savannah, GA
- 2014
- 3.0l turbo diesel
Laramie Crew Cab, 2WD, 1290 capacity per door sticker. 24' enclosed trailer, ~7200lbs. Tongue weight ~800lbs. Conventional spring suspension assisted by Airlift 1000 airbags (rear).
http://i465.photobucket.com/albums/rr17/RangerGress/Ram/RamTrailer_zps9c51ce73.jpg
http://i465.photobucket.com/albums/rr17/RangerGress/Ram/Airlift1000_zps57777b30.jpg
Rear end sag.
Height from fender to wheel, inches.
Unloaded. Rear 12 5/8, Front 10 11/16
Trailer hitched up Rear 9 5/16, Front 11 9/16
Put 40psi in airbags, trailer still on Rear 11 1/2, Front 10 5/8
Took trailer off, 40psi, Rear 12 7/8, Front 10 3/4
Trailer back on, hitch "tilted" forward 2", weight distro bars on, Rear 11 5/8, Front 10 7/8
http://i465.photobucket.com/albums/rr17/RangerGress/Ram/WeightDistroHitch_zpse4387eab.jpg
I'm working on moving the hitch ball 2" closer to the reciever. This shortens the lever arm the trailer has to move the truck around. This is significant both for truck F/R weighting also for sway. Moving the ball 2" closer means moving the hitch 2" deeper into the hitch receiver. This requires drilling a 5/8" hole in the solid steel hitch for the hitch receiver pin. I spent a bunch of time on this today but all I did was learn that Harbor Freight drill bits are only fine until you come up against solid steel. I got about halfway thru before my drill bit was useless so I'll have to buy some better drill bits and work on that later in the week.
Lessons learned
-800lbs drops rear end 3+ inches and raises front almost an inch. That's a lot.
-40psi airbags changed droop significantly. Rear goes up almost 2". Front down about an inch.
-With no trailer, 40psi airbags don't change ride height much.
-Moving the hitch forward (towards truck) 2" and putting on weight distro bars pretty darn tight changed ride height by only ~1/8". Therefore weight distro bars don't effectively counter rear sag. Note tho that weight distro bars shift do more weight when the rig porpoises so they still fight that pretty well.
-Towing mpg. Went for a 25mi test tow on a flat freeway at 64mph. 14.1mpg. For perspective, my 2000 F-250 diesel would have gotten 13-13.5. My old 2006 F-150 5.4l would have gotten 7mpg.
Lessons learned. I had hoped to get an honest 15-16mpg so this was disappointing. The diesel in the F-250 is regarded as one of the finest diesel engines ever put into a pickup and clearly it's a hard standard to beat. Gas engines suck towing heavy loads. It looks like I ended up with a very comfortable truck that gets great mileage when used as a DD, but isn't much of an improvement towing my trailer.
Towing heat issues. It was 85deg ambient during the above test. Both my coolant and oil got pretty darn hot. Coolant 224deg, oil 237deg. I did not expect this because 64mph on flat terrain didn't seem to stress the engine at all. It's the coolant temp that got my attention. I think I'm going to reduce the concentration of anti-freeze from 50% to 25%, and see how I might optimize air flow for the radiator. Antifreeze has lousy heat xfer specs, so you don't want to use any more of it then you need to. In Savannah, GA it only barely hits freezing a couple times/yr so 50/50 antifreeze is way overkill.
I also want to check if the radiator is adequately shrouded,and I might get a different grill. Radiator shrouds ensure that all air that hits the grill has no choice but to go thru the radiator. The blingly Laramie grill looks it might be blocking a fair amount of air.
Misc. Engine has all sorts of power. Just wish it had all sorts of cooling. Trailer brake controller works well. Since the freeway was flat, I did not engage Tow Mode.
Rear end sag.
Lessons learned
