Greeting gents/ladies,
Quick question for those who tow enclosed car trailers. Are there any secrets to stabilize the trailer more when it's empty? When the car is loaded and WDH, no sway. When the trailer empty, with or without WDH it wiggles every time I get passed by a semi or when the wind pick up.
more info
24' x 8.5'
4,130 empty
7,700 loaded
Also, I've seen on other truck forums that they have dedicated trailer thread showcasing different things that people have done to their trailer to improve functionally or aesthetics. Can we get one started here?
I have a 28'x 8.5' all aluminum enclosed Haulmark which is just under 4k empty. It is very stable when empty or loaded. The only time Ive had a stability issue is when I loaded my '67 K10 shortbed in backwards. Totally my fault and I knew better, but the front track is wider than the back and it would not fit between the wheel wells.
Mine has the "extended tongue" which they say helps with towing stability and control for backing up. Other than a camper, Ive not had an enclosed trailer, so I don't have anything to similar compare it to.
If its that bad, you could always install a hitch stabilizer as they do on travel trailers.
Great idea on the dedicated trailer thread. Im always interested in making mods and am planning to make mine into a dual purpose camper/carhauler as many have done.
It has factory installed aluminum front cabinets, drawers, and bench, roof A/C, rubber coin floor, 3' carpeted walls with recessed lighting on walls, coves, ceiling and above ramp. Also very bright LED "race lights" on the trailer-right side. It also has the generator compartment and in-floor spare tire storage.
So far I have only installed "x-track" from Northern Tools on the floor from front to back and on fwd left wall. I have been happy with it and plan on installing more on the walls. I also plan on upgrading the electrical system with a good clean inverter and adding a battery or two more.
I currently use a superwinch portable "toolbox type" winch with synthetic rope to reel vehicles in. It works well but I am still searching for a more permanent and possibly more "trick" setup. Any ideas and suggestions are welcome!
