My first tow
ddetta88
SLC, UT
Bought this truck less than a month ago immediately leveled it and put new tires on. Took the camp trailer out this weekend and it towed great. though I didn't tow any super steep grades
Has 8 speed w/ 3:92 rear end, there was a bit of sag I'm still trying to decide if i want airbags or just a rear spacer
I like the stance without the trailer attached so I'm leaning toward airbags
I also might need to readjust my equalizer hitch.
D
ddetta88
SLC, UT
With WDH set up right, you shouldn't have a sag.95ee004479a449cd0bece2d301906088.jpga56cdbc9f11e1c5402748da53b83acf0.jpg
Sent from my SM-G930T using Tapatalk
That's what thought but I figured with the front level the back might be more prone to sagging. I'll have to try readjusting it. I had it set up for my old truck and just moved the ball down on the shank I didn't change the angle or adjust the height of the sway bar connector things.
Farmer Fran
Earth
2020 Limited Loaded - Sold
Get a closer pic of the side profile of the hitch system... it looks like your ball might be too high, I say this lightly as it is only one picture but that sag is way too much for that setup from that pic.
Farmer Fran
Earth
Nice setup by-the-way, Have fun and be safe.
Please set the brake gain correctly
Iz48
Air bags all the way! Installed load lifter 5000 as I didn't like the ones that go inside the coil springs. Tow a 30ft enclosed trailer loaded no problem. Around 20psi in the bags and it's leveled. Well worth the money. Have 18k miles on them have yet to have a problem.
Farmer Fran
Earth
https://www.youtube.com/watch?v=x0OqqTjSsig
:hidesbehindsofa:
D
ddetta88
SLC, UT
Probably have been sitting level of it was still stock.
Quite possibly but then it would look like a RWD truck all the time.
