omg.. I didn't realize he had no idea. My bad-
Op-
Do you notice it takes longer to stop ur truck with 35"s? - it should because of the added weight and size of the tires. So take that into account when trying to stop. As far as not having enough power I can't tell wich motor you have but I see you have the 8 speed transmition- so am I safe to assume you have the 5.7 hemi? If you do when you mash the gas pedal does it Cherp those 35"s.
If it does then you clearly have enough power and torque to drag that little trailer around. Do you have a brake controller?
Also do you have a link to the stats of that trailer you are looking at?
Don't let three opinions sway ur mind - wait for more to post.
Anyone else with a lifted half ton towing that can chime in?
I did chime in......
My current rig isn't lifted, and it will not chirp the stock tires unless I turn off traction control.....
I have towed with a 1/2 ton rig that had more lift, more gear, and more power, and it still sucked. o
It did it, just like I said in a previous reply, but it had almost no acceleration and the sway and handling was at times scarey.
As I also said, he'll just have to be more careful. Sure he knows it slower now with the tires, and I'm sure he knows it will be even worse with the trailer.
