Need some help from the guys in the know..
H3MI UP
Southeast ga
I need to take the sag out of my ride while towing. You can see my set up in my signature. What can I do to not make my truck not squat so much while towing.
Nick@GotExhaust
SC
having the lift may make it a bit more difficult to find the right setup but air bags or stiffer rear springs are the usually fix
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Are you carrying anything in the bed? I'm suprised that boat has the tongue weight to squat the rear of that truck that bad.
You could opt for some sort of weight distribution hitch like an equalizer or something like that to transfer some of the weight back to the front end of the truck. Or as mentioned, air bags
H3MI UP
H3MI UP
Southeast ga
For some reason that picture makes it look worse than it really is. But I still want to try to help it out a little bit. I would do airbags but I have no clue on what to get with the lift. I was kind of in A low spot in the concrete which is why it looks worse than what it really is. Nothing was in the bed of the truck
SYKRAMMAN
Banned
Jersey shore
06 Mega
If you don't want to drop a lot of money then get a wdh for now, it will help make it not squat so much with that little bit of tongue weight.
WDH- couple hundred.
Air bags- a lot more.
Stiffer coils- a lot less.
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yes either the TLC bags or Timber Grove air bags.
5.7L Hemi 2500
From your signature picture it looks like it's always squatted in the rear even without a trailer? May need to add some lift to the rear to match the front. Shouldn't need bags for a boat/trailer that size.
H3MI UP
H3MI UP
Southeast ga
It just the way the picture looks. It’s actually level
H3MI UP
H3MI UP
Southeast ga
Here is another picture I took with the boat today. It doesn’t squat as bad as the other picture makes it out to be.
bbj02270
This is my setup with WDH. Second pic is unhooked, I'm riding stock. I did notice my sag had changed from first setup & had to readjust the Wdh7637c894a690a22e2af40a2e479aae25.jpgbeeb0f3221f2bd4620c43939654b2b89.jpg
Sent from my SM-G950U using Tapatalk
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
Don't worry about it. Actually, i would be embarrassed if i put a WD hitch on that small little boat trailer.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
i would worry about it and that's why the op posted in the first place.
imo - that's too much squat for such a light boat and trailer. the way the front of your truck is nose high, if you run at night with your lights on you'll be blinding people worse than you already are if you didn't get your headlights re adjusted after the front level.
it has to be a rear spring issue. double check your fender gaps front and rear and make sure they are equal, unloaded. with your level they should be or have a little rake rear to front.
this is why stock trucks come with some rake, the oems know we use our trucks so when loaded they sit level, or at least not as noise high as yours does unless over loaded.
your best bet i think is air bags if you dont want to mess with a wdh and actuslly, the frame of that boat trailer may not be strong enough for wdh anyway.. good luck
ColdCase
Its the lift thats giving you trouble. Any truck will sag just a little when a trailer like that is attached, and if you start out level, then you get a nose high attitude.
Thats a tiny trailer for a WDH. Your best bet is likely to add a bit of lift in the rear. Air bags are what many use as they are adjustable (you can settle the truck back level when unloaded).
Fbnmark
Virginia Beach
air bags are probably the best way to go as you can adjust them for how the truck is loaded. I've driven 2 trucks with the Timbrens and the best improvement was removing them.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yeah those timberlands are not really a good idea, Airbag up and you will be happy.
Jimray23
magnum v6
Just put airs hocks on the back. When you need to haul or pull a trailer air them up to 60 psi and get a 1 1/2 inch lift. Depending on weight you can all the way up to 150 psi. I think my shocks say they carry up to 30,000 lbs.
Jim
