HvyDuty
Can anyone find where someone was successfully sued for being over their Door Sticker payload? Doubt it.
After an accident, the opposing party or authorities would need to weigh the carnage to prove the overload condition. Good luck with that, ever seen a travel trailer crash? Not pretty. I think if the OP was pulling that trailer with a 1500 (ie grossly overloaded), that will probably result in legal action.
2500 Rams are down rated to meet the gov't spec 10k GVWR. Except for the coil spring rear, truck is identical to a 3500 axles, frame, powertrain all the same.
IMO, the OP should be most concerned with exceeding axle and tire ratings. And common sense thrown in for good measure.
