Jwithing
Hey all, looking to pickup a pallet of sod this weekend and wondering if I'll be ok to put it in the truck bed.
My truck is a 2015 sport CC 4x4 8spd w/3.92's, 6" BDS lift, 37x13.5x20 Toyo proxy open country r/t's (Plus tune and bolt ons).
I understand max payload is approximately 1,500 lbs
Tires are rated at nearly 2 ton each
Couldn't find any info on BDS lift effect on payload/towing
Pallet of sod weighs 1,500 to 3,000 lbs depending on moisture per google.
Will I be ok to drive this 11 miles home through hilly terrain? My first truck, and the payload seems extremely weak. I've put 1,500 lbs in the back of my 300C several times without issue, even with 22's. I know it's considered too much, but is it 'safe' for this short distance if I take it slow and steady? I know braking power will be severely affected of course. I don't have any doubts in the tranny or hemi. Any concerns with bottoming out the suspension? Not looking to make this a norm, but is there something I could do for better payload rating down the line (other than buy a heavier duty)? Can you put airbags in w/ a lift (not airlift 1000s)?
Companies won't deliver me one pallet of sod... Otherwise I'd go that route...
