mowin
- Mar 1, 2014
- 462
- 152
- upstate ny
- 2017 3500 SRW
- 6.4 hemi
Question....how do you get it so level????
Mine sits about 5 inches nose high and I can't fix it!!!
Sometimes you can raise you pinbox to lower the nose of the 5er. But that may reduce the recommended 6" clearance between the 5er and bed rails.
The next option is to flip your axles so there under the springs. If there already flipped, the next option you can gain some height by going to a larger tire and rim.
Most bring the 5er to a good frame/spring shop and have a subframe built and installed between the axles and Springs.
Check out rv.net in the Fifth wheel section for tons of info on leveling a 5er
I'm surprised your 2016 is sitting nose high.. my 2014 Laredo is perfect for my 3500.
