Receiver Hitch
NYCruiser
Yonkers, NY
My 2014 CC doesn't have a receiver hitch.
It has a class IV receiver hitch and spray in bedliner listed on the exterior equipment on the window sticker, and has both 4 and 7 pin plugs wired on the rear bumper.
Under the optional equipment packages 25C, which gave the truck 20 inch wheels and painted bumpers, etc, the Class IV hitch and bedliner are deleted.
Does anyone know what hitch hardware I need to buy to add back the Class IV hitch to this truck?
It looks like there is a knockout on the bumper for a bumper hitch along with support hardware under the bumper.
RAM 1500 ST CREW CAB 4X4
Exterior Color:Black Clear Coat Exterior Paint
Interior Color:Black / Diesel Gray Interior Colors
Interior:Cloth 40 / 20 / 40 Bench Seat
Engine:5.7-Liter V8 HEMI(R) MDS VVT Engine
Transmission:6-Speed Automatic Transmission
STANDARD EQUIPMENT (UNLESS REPLACED BY
OPTIONAL EQUIPMENT)
FUNCTIONAL/SAFETY FEATURES
Electric Shift-On-The-Fly Transfer Case
Trailer Tow with 4-Pin Connector Wiring
7 Pin Wiring Harness
26-Gallon Fuel Tank
Advanced Multistage Front Airbags
Supplemental Side-Curtain Front and Rear Airbags
Electronic Stability Control
Anti-Lock 4-Wheel Disc Brakes
Speed Control
Sentry Key(R) Theft Deterrent System
Power Accessory Delay
Automatic Headlamps
Locking Tailgate
Spray in Bedliner
Class IV Receiver Hitch
INTERIOR FEATURES
Front Armrest with Three Cup Holders
Second-Row In-Floor Storage Bins
Rear Under Seat Storage Compartment
Air Conditioning
Uconnect(R) 3.0 AM/FM
6 Speakers
Media Hub (USB, Audio Jack)
Rear Folding Seat
Power Front Windows w/ 1-Touch Up and Down Feature
Power Door Locks
Tilt Steering Column
Electronic Vehicle Information Center
12-Volt Auxiliary Power Outlet
Black Vinyl Floor Covering
EXTERIOR FEATURES
Halogen Quad Headlamps
17-Inch x 7.0-Inch Steel Wheels
P265/70R17 BSW All Season Tires
Full Size Spare Tire
Power Heated Mirrors with Manual Fold-Away
Black Door Handles
Black Front Bumper
Black Rear Bumper
Black Grille
PRICE INFORMATION (contd.)
OPTIONAL EQUIPMENT
Customer Preferred Package 25C $ 1,810
20-Inch x 8.0-Inch Aluminum Wheels
P275/60R20 BSW All Season Tires
Body-Color Front Fascia
Body-Color Rear Bumper with Step Pads
Fog Lamps
Carpet Floor Covering
Front and Rear Floor Mats
Delete Spray in Bedliner
Delete Class IV Receiver Hitch
Ramcharger Package $ 2,450
Uconnect(R) Voice Command with
Bluetooth(R)
20-Inch x 9.0-Inch Aluminum Chrome
Clad Wheels
Integrated Voice Command with
Bluetooth(R)
Uconnect(R) 5.0 AM/FM/BT
5.0-Inch Touch Screen Display
SiriusXM Satellite Radio w/ 1-Yr Radio
Subscription
For More Information, Call 800-643-2112
Overhead Console
Popular Equipment Group
P275/60R20 OWL All Season Tires
Sport Performance Hood
Rearview Mirror with Microphone
Remote Keyless Entry with All-Secure
Wheel to Wheel Side Steps
3.55 Rear Axle Ratio
Dual Rear Exhaust with Bright Tips
DESTINATION CHARGE $ 1,195
TOTAL PRICE:* $ 40,235
Assembly Point/Port of Entry:WARREN, MICHIGAN, U.S.A.
ncgrl1
Cajah’s Mountain NC
2020 RAM LongHorn 4x4
3.0 EcoDiesel
When you order the hitch, it comes with the necessary hardware needed. It actually mounts to the large round tube right behind the bumper, and the bumper itself. There are 2 bolts that you snake through the round tube with a wire, and 1 large bolt which goes where a normal ball would on your bumper. Hope this helps. Merry Christmas!!!
NYCruiser
NYCruiser
Yonkers, NY
I saw hitches like that online from Curt, I think, but they were only spec'd as Class III. If I get it from Mopar you think it will be the Class IV the window sticker referred to?
Oh, thanks for replying and Merry Christmas!!
ncgrl1
Cajah’s Mountain NC
3.0 EcoDiesel
Mopar states it has a 12,000 lb. towing capacity and a 1,200 lb. tongue capacity. That has more capacity than your truck. Having said that, mine is bent slightly to the right, and my travel trailer only weighed 6,000 lbs loaded. It was very noticeable when the hitch was installed. I have always been one to buy factory parts and accessories however I will buy one of the other brands when I replace my hitch. They all bolt up the same from what I have saw.
NYCruiser
NYCruiser
Yonkers, NY
Wow.
On closer inspection I see that the Curt hitch says it is Class III/Class IV depending on if load leveling is installed.
Whatever that means.
I'm guessing that has something to do with how the Tube that the hitch bolts to is connected to the frame. I'm also guessing that if RAM was calling it a IV it will have what it needs to be a IV other than the actual hitch.
I'll probably just grab the Curt reciever. Its like $90 shipped.
NYCruiser
NYCruiser
Yonkers, NY
OK - Just ordered this one. I'm sure it will be fine.
2014 Ram 1500 Trailer Hitch | etrailer.com
Specs:
Receiver opening: 2" x 2"
Rating: Class III
Maximum gross trailer weight: 6,000 lbs
Maximum GTW when used with weight distribution: 10,000 lbs
Maximum tongue weight: 600 lbs
Maximum TW when used with weight distribution: 1,000 lbs
Limited lifetime warranty
WhiteExpress
Midland, TX
That'll very likely tow anything you'll ever need.
I went with the traditional frame mount Class IV (next listing on that link above).
When I went to install it, I realized from the factory it's all there, other than the little drop down piece.
Oh well.
JohnD72
Charleston, SC
Curt Manufacturing 14374 Class IV Receiver : Amazon.com : Automotive
That's the full class IV Curt hitch from Amazon for $148 that WhiteExpress is talking about.
Just installed one on my Sport.
The "load leveling" they are referring to is most likely a weight-distributing hitch. It does exactly what the name describes - and stops excess sag in the rear of the truck.
ncgrl1
Cajah’s Mountain NC
3.0 EcoDiesel
You done good. E-Trailer is awesome! I ordered my fifth wheel hitch and custom mounting kit from them. There was a problem with the mounting kit from the manufacturer. E-Trailer went above and beyond to get the problem straightened out. Kudos to them. They are a great bunch! Your hitch should arrive very quickly.
NYCruiser
NYCruiser
Yonkers, NY
They already emailed me and told me it was in stock and would ship within 24-48 hours. Said they will send tracking info as soon as it does. Can't ask for more than that! Thanks for everyone's input.
//Andy
NYCruiser
NYCruiser
Yonkers, NY
That's a stout looking hitch. I'm not sure if it is really any stronger than the support that is under my truck already from RAM. The factory hitch support looks to be welded like an extension of the frame and the hitch part just bolts to it - as opposed to the curt IV that bolts to the frame. I'm guessing that your Sport didn't have the hitch at all from RAM?
BTW - Still can't figure out why they bothered deleting the hitch from my truck. I guess they wanted it to look sporty? LOL
WhiteExpress
Midland, TX
Completely agree. I have had nothing but good experiences with e-trailer.
Called my service rep's manager to say what an awesome job she did.
