Mudder
My truck didn't come with a hitch so I added a class III Curt hitch over the weekend. Factory style that just bolts to the crossmember and up through the bumper. So I only have a 150 ft/lb tq wrench. I did the back two to the specified 110. The main bolt in the front calls for 380 ft/lb. I maxed mine to 150 and figured I'd ask the shop or delearship to do it when I'm there next time.
Two questions though. I went to mess with it a day after installing and I could neither tighten or loosen that bolt even with a breaker bar. Any suggestions on breaking it loose? Also, it is irking me that I can't get the little plastic cap back on the bumper to hide that bolt. If I get it tq to 380 should that get the the clearance to get that cap back on? Gotta look clean don't you know.
