1500__Driver
- Nov 28, 2012
- 5
- 0
- 2012
- Hemi 5.7
I'm sure there are threads addressing this, but I can't find them cause the search function eliminates most of my key words because they are too 'generic' or short or whatever.... all i can get it to search for comes back with only 'suspension' in the search. Arrrgh...
Anyway, wondering what recommendations for a rear air bag suspension kit?
I regularly, (all though not necessarily often...) have the need to load the bed of the truck in the range of roughly up to 2500 lbs (+/-). Not a daily thing, but for sure regular, which is why I stepped down from a 3/4 ton to the 1/2 ton. I also regularly, but again not daily, tow a 8 x 16 cargo trailer, loaded at various weights. By far most of the time the truck is unloaded, but at times will get a good workout. When it is loaded, it's usually pretty heavy. Probably a little less stress when towing the trailer, but even then, probably still more than healthy for a 1500.
Given my needs, I think the new Hemi, 1500, that I just bought, will work just fine, if I install air bags in the rear for use when needed.
Any insight from anyone who has installed them? From the bit of research I've done, the 9" air bags from Total Load Control look good, but maybe a system with smaller bags, but higher PSI , inside the coils is better?? Would think that the further out the airbags are, (in the springs) could be better, but the larger diameter, and lower PSI of the TLC system makes sense too.
What about auto leveling kits? Worth it? or just as good with something to be manually adjusted? Either way I'm going with something that has a compressor on-board so I can adjust when I need it. Don't like the idea of having to have, or find an air compressor every time I load up, or want to adjust the ride....
Thanks!
Thanks!
