Stock tire vs trailer ?
danmp
Québec city, Canada
Does the 17" stock tire have enough ply to tow a 4000 lb trailer ? Around 500 lb tongue weight
h2oman
SoCal
Yes. Air towards max. You're still way under payload with that setup.
NYCruiser
Yonkers, NY
X2- Yes. The rated payload/tow rating is applied with all the stock equipment installed.
audio1der
Airdrie, Alberta
Even the Pentastar V6 with `17's wouldn't struggle with a 4,000lb trailer.
danmp
danmp
Québec city, Canada
Also, does I need some air lifting or support like the air lift 1000 with a trailer of this weight ?
NYCruiser
Yonkers, NY
I wouldn't think so. Hook up and pull it. If you feel you need airlift, you can always add it.
audio1der
Airdrie, Alberta
^ Agreed. Try it once and see; your worst case scenario is ugly sag, but it is nothing that will hurt the truck.
Brakelate
South/Central Utah
Correct. Everybody is providing good, accurate info. (As Usual).
Just thought I would give you a vote of confidence.
:favorites37:
Ocelot
My camper is just under 4000 lbs but I think my tongue weight is more like 600 lbs because it's a single axle trailer.
Anyway, the tongue weight is no issue at all. I do use an Equalizer Brand weight distribution hitch though. That's because I wouldn't tow any full height trailer without the the sway control that the Equalizer offers and the weight distribution takes some of the rear drop away.
Also, I only have the 4.7
the 4.7 is the newer 4th gen one though that has 320 HP and over 300 lbs torque. With my light camper the Ram stays nice and cool up steep grades even in 90º heat.
Ray
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Should not even need a weight distribution hitch at that weight. If you have the stock tires they might be a little spongy but will work fine.
Ocelot
Oh true, you can do fine with that weight without a WD hitch. But it always helps. Even bumps and dips in the road cause a lot less bounce in the rear with a WD hitch.
It's one of those things that's really nice to have at lower weight campers and a necessity with higher weight campers. Kind of like tuners and even Hemis aren't needed, but certainly nice to have.
Ray
danmp
danmp
Québec city, Canada
Good, thank you for the information
I didn't needed wd Hitch with my sierra and my actual trail since the Hi-Lo are low.
But I planning to change it for a " normal " trailer and I never towed it with my ram .
I guess a wd Hitch will be not bad with a higher trailer and the ram.
UPNO4
Utah
2013 Laramie , 2023 Laramie
Hemi 5.7 8spd, 6.7 CTD
4000 lbs on these trucks is like packing in some groceries. Truck won't even now its there. I hook up to 7000 lbs all the time. All stock now worries
I haven't used a WD hitch yet. May be awesome but if you are loaded correctly all is well. Just check state reg on trailer brake requirements. Most of the ones I have seen require them at 3000 lbs or more
