tow/haul button
reek
Sacramento
So trying to live with my 5.7 6 speed, I've been experimenting. Running my truck with tow/haul on, it seems to top out in 5th gear. I understand that its just an adjustment of shift points and apparently final gear, but outside of gas mileage, any harm if I continuously run the car in tow/haul mode? I like the shift points significantly more than the regular shift points and gets rid of most of the "bogging" issues with this crap 6 speed trans.
MADDOG
Not RamForum Staff
I ran my 2007 MegaCab 5.7L HEMI in tow/haul all the time. I did go to full auto cruising down the freeway when not towing.
No trans problems in over 140K miles.
dearchristopher
Galveston, TX
your temps will always be lower out of 6th gear with a load. sitting in 6th lugs the trans and builds heat. I only put it in tow haul when I'm towing, I like full auto and mds at highway speeds. I do leave my truck in 5th (manual shift) around town, to get rid of mds. I have noticed that mds in town will drop my mileage significantly, but on the highway it does help. leave it in tow haul around town, the shift points are a lot nicer and take advantage of the power band better
Sent from my LG-D850 using Tapatalk
R
reek
Sacramento
this was my plan exactly! thanks
guzzel
Agreed! I like the shift points a little better while in Tow/Haul mode.
R
reek
Sacramento
I've since gotten my chubby little hands on a Diablo tuner. For a start, turned off the MDS. SIGNIFICANTLY better already. Haven't done any other adjustments yet. Want to go one step at a time and see what gets better/worse with each change. So far, I'm almost able to live with the 6 speed.
