Tow Specs for 2015 Outdoorsman
lanceohemi06
Northwest Florida
Ram bodybuilder site is not working for me. Can someone point me to the cargo and tow ratings for the 2015 Ram 1500 Outdoorsman 5.7 Hemi, 4x4, 3.92 gears, crew cab, 20' wheels?
crash68
ACME product engineer
Administrator
3.0 EcoDiesel
Here you go: 9850lbs trailer with a GCWR: 15850 add about 200 lbs for the 5.7' bed. 768e6de5781a4b1efb95fd4e484ed246.jpga3ce52a590c7dfeff084f5ba2d2a246f.jpg
cbsmith
New Brunswick, Canada
2014 Ram 1500 Outdoorsman
The door jamb sticker on my 2014 Outdoorsman with 5.7, 3.92, CC, 4x4, 17" wheels is 1181 lbs. tow rating is I believe 10,300lbs.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Wow, 1181lb payload, are you sure that's right? Seems really low. I believe large SUVs have around that much.
BossHogg
Oakland Township, Michigan
6.7L Cummins
Sounds right, my 2013 Laramie 1500 has a 1,081-pound payload rating. Truly the definition of a half ton truck. In contrast, my 3500 is just about 4,000 pounds payload rating.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
Ok, sounds good, thanks
RamInfo
Utah
5.7L HEMI
That payload seems light for an Outdoorsman; I thought that package included a suspension upgrade. My 2016 Laramie CC door sticker says 1253 lbs. That must be a very well-optioned Outdoorsman!
DG
Mchurch52
Shreveport, LA
EcoDiesel
I had a 2014 Outdoorsman, payload was just over 1200 pounds. Ended up buying a travel trailer so had to trade it in for a 2500 Outdoorsman to get more payload. While the 1500 Outdoorsman has upgrade shocks, the coils are the same and that is what limits the payload.
cbsmith
DG
It's got everything except parksense and has the factory air ride suspension.
Is your Laramie a 4x4? That is about the highest payload I have seen posted for one.
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
my 2016 Laramie qc 4x4 has a payload of 1342 according to my door sticker
talk2cpu
2014 1500 Bighorn Crew
Hemi 5.7, RamBox
We are truly very limited with a RAM 1500. Looking at the OP question and the info provided in one post of a 10000+ tow capacity, you would have to be very careful on your hitch weight.
RamInfo
Utah
5.7L HEMI
Yes, the truck in my sig is 4x4. No park sense, rear defrost, or tow mirrors and has 60/40 front bench, which I specifically wanted for traveling use. Does the air suspension option reduce payload rating, beyond just the added weight of the option?
DG
cbsmith
No, it still has a 6900 lb gvwr, it just adds weight to the truck with the air tanks and compressor.
