2013 Ram 1500 Longhorn Laramie
We have a 2013 Winnebago Vista (30T) with a Ford Chassis (F53) and V10 Triton and we pull a 2013 Ram 1500 Longhorn Laramie. We were pulling a 2014 Jeep Grand Cherokee Overland for a while, but I wanted to get back into a truck. Yes I agree that a Jeep Wrangler is easier to shift the transfer case into neutral (pull lever into nutral), but the rest of the hhok up is the same wether it's a Wrangler, Grand Cherokee or Ram 1500, (you got the tow bar, towcables, wiring harness plug, break away cable, Brake buddy setup and checks). I can do any of theses in about the same amount of time, have done them all (98 TJ, 93, 95, 98 ZJ's, 2014 WK2 and now Ram 1500) all have their differences and all have a different level of comfort. My 2014 Grand and 2013 Longhorn are almost the same in trim level (Loaded) and that's what I like. No you do not have to change your setup at night when you stop, as long as your not using the vehicle (do due a walk around in the morning and check lights, pins and Brake Buddy system) as we had someone remove a pin one night while we slept (some worthless piece of dung). Yes you need to follow the Recreational towing in the owners manual, start the vehicle, transmission to neutral take your ball point pen and press the little button on the transfer case neutral switch till it flashes red, then stays red, shift into drive on transmission and truck shouldn't move with foot of brake and parking brake off. Let the engine and drive line slow down before attempting to shift the transmission into Park or you will hear a clicking or grinding sound. After trip start engine **** transmission into neutral and press 2wd on transfer switch, shift into drive and your off, always remember that when the transfer case is in neutral the vehicle could roll freely so use your Park Brake (Emergency Brake) for safety. Yes I know I would get better gas milage with a smaller vehicle, but I Don't want a smaller vehicle. My RV is short 30 foot with 3 slides, plenty of room for the wife and I and 2 small dogs. I can pull into just about anywhere without issues because of its shortness. I could fly and then rent a car and stay with family or friends, I could drive and stay in hotels and pay every night or I can take my RV and my Toad and go where I want when I want and stop wherever I want. So happy trails to you.
