So my current setup is a 2016 2500 CCSB with the 6.4 Hemi and I am pulling a 33 ft Coleman TT with a 7900# dry weight. I am using an EAZ-lift 10,000# WD hitch. Currently I have the 2" shank and I am using the sleeve that came with the truck. I am in the market for the 2.5" shank, and I think I've found one, but I am not sure it will meet my needs.
My issue is that my current hitch has a 6.25" drop and the only class V replacement shank that I have found also has a 6.25" drop. Here is the shank in question: http://www.etrailer.com/p-C17128.html
That being said, with the height of my truck it causes the trailer to be slightly nose up while towing, even with the WD all hooked up. I have attached a picture to show the stance. My ball is angled sharply back towards the trailer, which is how the dealer set it up for my 1500. If I angle the ball to 90 degrees will this level out the trailer? Do I need more drop? How is everyone with a 2500 and a TT going about this? I feel like I can't be the only one with this problem with the height of these beautiful trucks.
