U&A
- Apr 29, 2016
- 9,261
- 18,563
- Michigan
- 2016 3500 SRW
- 6.4 HEMI
first let me get off my chest that this was my first experience with E-trailer and it was a pain in the A$$ to deal with. my order did come in a reasonable amount of time, exactly 1 week, but that is because I got them to "expedite it" because of the issues.
anyway...this thing truly is a piece of art...
THE GOOD
I have not used it yet as I just got it last night so this is just a first impression on fit and finish, appearance and what not. the excellent news is if your truck has the storage boxes in the floor of the cab under the back seat floor mats, the 8" drop for the 2,5" receiver with 3 different balls and a locking pin fit in their perfectly. if you get anything longer than an 8" drop it wont fit.
the machining finishes on it are very smooth were parts are sliding on each other so there is no binding of any kind. the is absolutely no alignment issues with anything making it easy to operate quickly. all the exterior edges are radiused and look to be somewhat polished to a smooth corner. All the unfinished surfaces are in a raw state with what looks to be maybe a slight polish to remove scratches. there was not a single scratch in the thing. the weight is substantial and gives you confidence in the 6061 aluminum's strength. I really like how the capacities are stamped into the side of the ball mount for reference as well as stamped on the top of the different sized balls. All pins fit perfectly with a very very slight amount of play. the other good thing is they are no longer using the scale that maxes out at 1500 (numbers displayed) at the top of the gauge and then a big read bar after it. mine will read all the way up to 3000lbs. more than enough. When its on my truck I have just over 13" from the bottom of the ball mount to the ground. that is perfect for me. The Stainless Steel balls themselves have a very nice finish and done well. the raw finish looks nice and the hole that they drop into on the mount is a nice fit for them.
THE NOT SO GOOD.. (it doesn't hurt anything though)
the only thing about it I don't like is the somewhat loose fitment of the ball mount itself ( the up and down slidey thing)that houses the hydraulic scale, to the 8" drop. It has a little more play between the 2 parts than I was hoping for but it is still better than the other aluminum and steel adjustable ones out there. To play devils advocate, I completely understand why they did it though. If dirt/road grime gets in their it still needs to be able to slide up and down without binding. it could get stuck pretty good if enough dirt got in between them, say from a dirt road. If you are a gun guy you will understand me when i say that everything else fits like an Ed Brown 1911. but the scale ball mount itself is closer to the fitment of an AK....if that makes any scene to you. I can live with it no problem though as I know it was intentional and not because of poor quality.
JMO. I can post pic late tonight.
THE GOOD
