Here we go...
This is the top of the insert that goes into the receiver. The 2 dimples on the (photo orientation) top and bottom are indentations from the insert moving around in the receiver... You can also see at the left of the picture the actual contact area
This is the bottom of the insert. The distinct line is actually a groove where the inserts rides on the edge of the receiver opening.
The stamped rating on the insert..
Next to the Reese Titan for comparison...
The heaviest thing my weigh safe has hauled is my empty dump trailer. 4000 pounds. And it only did it once. Ive pulled my 5x10 utility trailer a total of 3 times with maybe 1000 pounds on the trailer. I would expect a hitch of this financial commitment to not show this kind of wear with such little use.
